1965 - 73 Porsche 911, 912 Set of Rear Seat Belts and Buckles. These are used seat belts and are over 35 years old. You should inspect them and determine if they will suit your needs. One of the plastic loops on the back of the belt is broken so the loose end flaps free. They look decent and should clean up with a bit of scrubbing. $17
Save Shipping, pick up your part at the Stoddard Meet on Sat June 12
Sign up for our Ebay Email newsletter and see our latest listings.
http://cgi.ebay.com/ebaymotors/1965-...Q5fAccessories
1965 - 73 Porsche 911, 912 Pair of Seat Track Risers. These are the metal brackets that attach to the floor for the seat tracks. They are in good used condition but should be repainted. $17 To be sold without a reserve.
1965 - 73 Porsche 911, 912 Set of Four Seat Rails. These are used seat slider rails in good condition. $17 To be sold without a reserve.
1968 Porsche 911, 912 Amber Side Reflectors. These are the 1968 only side reflectors. They still have the mounting studs on the back. Not available in stores.......... $37 To be sold without a reserve.
http://cgi.ebay.com/ebaymotors/1968-...Q5fAccessories
1965 - 1973 Porsche 911 Engine Lid Latch. This is the latch that mounts on the body of the car. It is in good used condition. $7 To be sold without a reserve.
1968 - 1973 Porsche 911 Sportomatic Shifter Knob. This is a used shift knob 1,2,3,4,R. The clear plastic shift pattern has the usual hair line cracks. The black plastic knob is in good condition. Only on a Sportomatic..... $9 To be sold without a reserve.
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
1969 - 1972 Porsche 911 Front or Rear Disc Brake Pads, also fit 1973 - 1984 Porsche 911 Rear Brake Pads. These are New Old Stock built by Wagner, Power Max PD 43 A. $9 To be sold without a reserve.
http://cgi.ebay.com/ebaymotors/1969-...Q5fAccessories
1965 - 1969 Porsche 911, 912 Shift linkage Access Cover. This mounts on the floor between the seats to gain access to the linkage coupler. It will need to be repainted before use. $7 To be sold without a reserve.
1965 - 1969 Porsche 911, 912 Chrome Trans Shifter Assembly. The chrome on the handle is decent for street use. $17 To be sold without a reserve.
Porsche 911, 912, 914 Over 21 Pounds of Hardware, Fasteners, Susp Strut Top Collar Bolt, Shock Mounts, Nuts, Bolts, good Stuff. This is a good collection to have under your work bench. $9 To be sold without a reserve.
1974 - 1989 Porsche 911 Front Sway Bar. It is 20mm diameter. This is a used sway bar. $17 To be sold without a reserve
http://cgi.ebay.com/ebaymotors/1974-...Q5fAccessories
Porsche 911, 930 Throttle Linkage Pivot Assembly. Porsche # 930 110 360 02 also # 19473. This is a good used part. The pivot works smoothly. $7 To be sold without a reserve
