Thread: Sourcing 2.0s Piston Rings
    Member #1525 gilbert911's Avatar
    Oct 2006
    Europe
    Progressing with our std/std rebuild on early (alu case) 68 2.0S engine that I got via Richard on this board. Ready now for piston rings. Are these difficult to find?? - Need a full set of OEM rings. If anyone can recommend a source where I can get a set that would be great!
    Thanks in advance.
    Restoration newbie.
    Jun 2007
    San Francisco
    These are pretty hard to find. I think I have a source.
    They were able to find me a set of 80.5mm oversize
    Mahle rings (although they haven't arrived as yet)
    Send me an email through the board.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Jan 2003
    UK
    Chris - good to see you posting again !
    Have you tried David Leopold (davidppp here & on DDK) in S Wales ?
    Or Mike Bainbridge (MB Engineering) in Cumbria ?
    Andy
    Early 911S Reg #753
    R Gruppe #105
    I would like to know why no one seems to want to use Deves rings in their 911? I use them and am satisfied with them. Has anybody had a bad experience with them?
    Restoration newbie.
    Jun 2007
    San Francisco
    Doing a search for 'Deves' in the PP engine building forum is
    why I avoided them.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    DynoDave
    Dec 2004
    Highlands Ranch, CO
    2.0S Piston Rings
    Several months ago, I contacted Total Seal (800) 874-2753 in Phoenix as I needed a set of 80mm rings for a 2.0 engine build. I installed a set of Mahle 906 pistons in my engine. They utilize the same width rings as the 2.0S Mahle pistons. When I checked Total Seal's web site, their online catalog showed that they carried the correct rings, however when I called to confirm, I was told that they did not have any in stock. I don't remember the name of the man that I spoke with at Total Seal, but he did follow up with me to let me know that they could make a set. Total Seal's lead time turned out to be too long for my project. So, after several other phone calls (Andial has not carried them for a very long time), I was able to piece together a complete set of Goetz rings (rings for 5 pistons from from EBS in Nevada and rings for one piston from a friend at a local Porsche mechanical shop). You may want to call Total Seal as I am not aware of many other options beside the Deves rings which several Porsche engine builders that I know said would not be their first choice. I hope this helps.
    Dave
    Member # 351
  1. FS: 2.0L piston rings
    By typ901 in forum For Sale: 911 Parts
    Last Post: 01-06-2013, 08:49 PM
  2. FS: piston rings 2.2S
    Last Post: 01-20-2012, 09:14 PM
  3. FS: piston rings 2.0L 2.4L 2.7L
    Last Post: 05-11-2011, 07:52 AM
  4. OEM 67S 68S piston rings
    By ajwans in forum For Sale: 911 Parts
    Last Post: 11-05-2008, 04:23 PM
  5. WTB: 2.0S piston rings
    Last Post: 07-24-2008, 05:22 PM
