Thread: gasoline vapours
    gasoline vapours
    Hi,
    recently I have been experiencing gasoline smell in cabin after filling up. This lasts for about the first 10-15 miles after fuel stop. Has anyone had this problem? we spotted some faded stains on the top of the tank (where the fuel level measurement device is inserted) so replaced the rubber seal in it as well as the seal on filler lid. Any thoughts/suggestions anyone for further investigation or fixes? thanks.
    Lightbulb
    Stack,
    Simple search comes up with a number threads....... try this one:
    http://www.early911sregistry.org/for...ght=fuel+smell
    Hope this helps
    thanks
    good point! thanks. Useful link indeed.
    Add a second gasket to the fuel cap, or cut a piece of inner tube rubber to size and put it under the existing gasket. That cured my gas odor problem. If it doesn't work you're only out about ten minutes!
    jhtaylor
    santa barbara
  1. High Octaine gasoline for sale in Southern California?
    By davewadd in forum General Info
    Last Post: 05-17-2011, 08:10 PM
  2. E.P.A. Approves Use of More Ethanol in Gasoline
    Last Post: 02-06-2011, 04:46 PM
  3. Caffeine and Gasoline at Griot's Garage tomorrow
    By AlfaGTA in forum Evergreen (Washington)
    Last Post: 02-04-2011, 07:27 AM
  4. Bad Gasoline = Backfiring?
    Last Post: 02-09-2006, 07:48 AM
  5. Webasto Gasoline Heater
    By jaudette3 in forum Technical Info
    Last Post: 01-03-2006, 06:22 AM
