Complete, rebuildable 1969 911S Engine, in parts or whole:
1969 911S Case #6391515, Type 901/10, in excellent condition (no issues), 24 Steel Head Studs...$1,000
Oil Pump and Intermediate Shaft...$50
1969 911S Crankshaft, Standard/Standard, in excellent condition (no issues)...$1,000
1969 911S Nitrided 2.0 Rods, Great complete set of 6, excellent condition...$600
'Carrera 6' 906/C-6 Pistons and Cylinders. Look somewhat worn, probably "runnable" but not the first choice in a rebuild. $650
True "308" part numbered, complete set of six (6) flawless '69S Heads, correct date codes, 36/35mm ports, and large 45/39mm valves...$2,500
Correct 3-bearing cam towers, with rocker arms, all timing gears and parts...$100
Red Fan Shroud from 911SC, looks painted...$40
245mm Fan and 901-5R Magnesium Housing, with replated (Cadmium) fan and crank pulleys, in excellent condition, with alternator...$450
'69S Mechanical Fuel Injection (MFI) Pump. No damage. Originally #001, re-stamped by someone at some point with #005. Early date code. I checked-it has the correct '69S #047 3D Space Cam inside. Dual Solenoids like all 2.0L's had. Excellent. $1,000
'69S Original "901" part number (one-year only, '69) 911S Mechanical Fuel Injection (MFI) Throttle bodies, stacks and air-cleaner. These seem decent for this age of car, but they probably will need servicing relatively soon. However, they are excellent "cores" to start with, as there are no crucial broken or missing parts. They are all there...$750
MFI Cam Pulley, decent/good...$75
MFI Fuel Lines, fine...$60
MFI Injectors, probably need work...$200/set of 6
Engine Tin, Complete set for '69-77 car, with cylinder tins, all surrounding tin in black powdercoat...$350
Excellent, excellent Bosch "007" Aluminum 911S Distributor, correct for '69-71 911S, tested very well for a used distributor...$500
911E Camshafts, excellent, 911E part numbers but I do not know what grind they have (if any). Even 911E cams are good though. These of course have MFI Drive. $325/for the pair
Also available as a package deal for $9,000.
All parts are truly excellent. Great motor to start with.
Scott
KinderSport@gmail.com
