Results 1 to 7 of 7
Thread: 901 gearing for a 2.5l engine
    Jul 2003
    Vienna, St. Gallen, Stuttgart
    I run a 2.5l twin-plug engine in my 911S SWB and this powerhouse really puts the strain on my gearbox. That's why I think of having a new, stronger, and better geared box built.
    As a variation on the theme of a recent thread (http://www.early911sregistry.org/for...ad.php?t=34825), I wonder what the best gearing would be for my engine. I would be very grateful if you could give me your views regarding the following issues:
    1. I would like a top speed of 145mph at 7500 rpm in fifth. This should ensure a sensible rev level on the autobahn. With my stock gearbox, the engine easily pulls 155mpg on the speedo. And yes the car feels very light at that speed.
    I will drive the car in road events and for fun drives on mountain roads, so 2-3-4 need to be reasonably short. To prevent frequent issues, 1st should be a short gear, only for starting.
    2. Who offers modern and proven quality parts for the 901 gearbox? I already run an English Tuthill lsd and want to build the gearbox for high reliability.
    3. What further measures are typically employed to strengthen the 901 box when used with a stronger engine?
    Thank you very much for your help!
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Jan 2003
    UK
    Hi Anatol - have a look at this thread for some useful info :
    http://www.early911sregistry.org/for...t=transmission
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Jul 2003
    Andy, thank you for pointing me towards that thread.
    Did you go with AEJQX? Judging from the thread, this seems to be a good choice.
    Now, what can there be done to strengthen the 901-gearbox? And any recommended gear suppliers?
    Thanks again!
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Jan 2003
    UK
    Hi Anatol - yes, I did go for A,E,J,Q,X but I haven't driven the car yet (it's still in the build stage) so can't comment on the suitability of the chosen ratios.
    One of the weak points in the (magnesium-cased) 901/911/914 transmission is the intermediate plate & a std 'upgrade' (when mating to a high power or high torque engine) is to replace this with a billet aluminium version (which has been done on mine).
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Jul 2003
    Andy,
    thanks again! Where did you source the billet intermediate plate?
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Nov 2003
    Santa Monica CA
    plate
    Anatol-- Try Performance Products.com or Stoddards both in the USA
    Restoration newbie.
    Jun 2007
    San Francisco
    Having a SWB car your intermediate plate is aluminium already, unless
    you have a later gearbox. I believe the 1969 901/13 is the first mag
    cased gearbox (901/12 if you had a four speed)
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
  1. Gearing Question
    By Sisuman in forum Technical Info
    Last Post: 06-23-2012, 05:07 AM
  2. US vs RoW gearing
    By Jules Dielen in forum Technical Info
    Last Post: 11-07-2011, 08:54 AM
  3. 915 Gearing References
    By gtgroupe3 in forum Technical Info
    Last Post: 02-11-2009, 01:13 PM
  4. Help with Gearing..
    By Mudi in forum Technical Info
    Last Post: 04-18-2008, 07:50 AM
  5. 901 SWB trans gearing
    By Fritter in forum Technical Info
    Last Post: 12-02-2007, 04:05 PM
