Results 1 to 7 of 7
Thread: Simplified Wiring Harness 1971 911S
    I am researching for my next round of upgrades. One thing I want to do is sort the wiring since there are so many things crossed up, not working, or working intermittently.
    Can anyone provide their source for a simplified wiring harness? I have heard of some using a VW Beatle DIY harness, from Painless Performance I think. Also I am looking for any advice about the installation process.
    The car has the following items that I will need to connect together properly:
    H1 headlights in H4 lenses (I think- my spare bulb is in an H1 box but I have plastic lenses) with high/low beam switch and dipper
    hazard flasher
    turn signals F+R
    brake lights
    horn
    windscreen wipers
    kill switch
    alternator light
    oil pressure light
    S gauges (fuel/oil level, oil pressure/temp, tachometer, speedometer)
    lights for gauge faces
    fuel level sender
    oil pressure sender
    oil level sender
    oil pressure switch
    oil temp sender
    MFI speed switch fuel shutoff circuit
    starter
    single plug ignition
    Bosch CDI box
    cold-start squirter solenoid
    MFI electric fuel pump
    and I believe that is everything.
    I would also like to add relays to keep the ignition switch from going out if I ever need to drive at night.
    Battery is a small interstate, sealed lead-acid plate type, 33 Amp-H
    Peter Stey
    1973 T Coupe with 2.7MFI
    1970 S Targa (sold but not forgotten)
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    You can also try here: http://www.riwire.com/
    They don't list 911's but they do have quite a few 356 wiring harness's listed. I'm sure they may be able to come up with something for our cars
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
    Hmm, more expensive than I thought. Thank you for the links, though. Maybe the 904 harness.
    I was looking for a more built-it-yourself harness that would not have the Porsche tax. I would only be putting in the minimum number of circuits, since this is not in any way an 'original spec' car.
    I appreciate the responses.
    Aug 2003
    Van Nuys, Ca
    There are places that sell vw harness kits for around $35. but you get what you pay for !
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    hazard flasher complicated
    turn signals F+R
    brake lights
    horn
    windscreen wipers
    windshield washer
    kill switch two circuits necessary
    alternator light
    oil pressure light
    S gauges (fuel/oil level, oil pressure/temp, tachometer, speedometer (electronic?))
    interior & trunk lights?
    fuel level sender low fuel warning light
    oil pressure sender
    oil level sender
    oil pressure switch
    oil temp sender
    starter
    Bosch CDI box
    Time-Temperature switch
    I would make your own using original Porsche wiring from salvage harnesses. With black heat-shrink, you can make it appear original while loosing the non-desired circuits and adding what you need.
    A 1971 (’70 actually) has the very standard wiring carried forward for many years. The ’69 was unique and SWB was always changing and not applicable to your ’71.
    I would start with a complete harness from a ’70-’73 salvage. This will let you locate all the connections to components.
    There are some necessary conventions it is worth continuing. Wire color is most important I feel. So is the interchangeability of the engine harness 14-pin connector and the 14-pin connector between the engine electrical panel and the main harness.
    You want to continue with the standard ignition electrical switch, the headlight switch and the two switches on the steering column. All of these mating connectors are available as spares or can be un-soldered from salvage harnesses. Remember, these are silver-soldered.
    You will also want to continue with the standard connectors for the turn signal assemblies. I would add a pair of similar connectors for new headlight wiring. Make them impossible to mis-connect with the turn signal connectors. Mount the attendant headlight relays in the normal relay mountings.
    Not using the fresh air blower will simplify that mess. If you use a blower, make it off-on on high only.
    Your car has the provision (or perhaps installed) the intermittent wiper delay circuits. If you want to retain (or install) the intermittent feature, use the later version that has adjustable delay.
    Your ’71 has the electric fuel pump in the rear. You will want that on the front cross member. Note how the pump wiring is on a ’70.
    You have an extra green wire in the main harness for the Sportomatic over-temperature indicator. Retain that for your addition of the oil pressure switch (your car is not wired for both oil light and gauge).
    I would add the pair of wires for twin ignition cutoff switches (above, either side of the tach). Someday ….
    I suspect you may want to maintain the brake warning light.
    You might add low brake fluid warning light(s).
    You certainly don’t need the seat belt light.
    Remember all the grounds that are in the harness. An important feature of out cars are those ‘common ground’ studs braised onto the chassis. I would separate out the common grounds in the harness itself. They are very difficult to trouble shoot.
    Starting in ’74 the main battery wire in the chassis was enlarged. The larger version will fit your chassis.
    I would make the yellow starter wire one size larger. Be sure to silver solder the connections.
    I think Wurth has most of the original Factory connections.
    I’m sure there is more.
    Whatever you do, do not remove your harness until you have the new one built, tested and test-fit to some empty shell.
    Best,
    Grady
    Wow, thank you very much Grady for the thorough response. That is just the kind of information I wanted. I will save this reply until I am ready to begin the next round of upgrades.
    To clarify, this is halfway to being a racecar. I have no trunk/interior lights and no windscreen washer. I do not actually remember if the intermittent wipers are working as they are not installed on the car right now (southern California ) but I do have the motor working. I have no fresh air blower.
    I have only one kill switch, mounted on the cowl. Does that still require two circuits?
    The transaxle is a 911/01 Magnesium case with early AFMSX gears, 7:31 ring and pinion, and non-simplified differential. I thought that this is a mechanical speedometer, with electronics starting after a few years of 915 production. I just wanted to mention all the gauges in my post since there are illumination lights for all of them.
    Thank you for your advice. I will be sure to incorporate the larger wiring, relays, and warning lights.
    Quote Originally Posted by Grady Clay
    I thought that the light above the alternator light on the oil temperature/pressure gauge was for low oil pressure, with the signal coming from the switch on the front of the engine. You are saying the wires coming from the switch on the engine are not going to the gauge? Or has my car been upgraded? I do not recall seeing the low oil pressure light illuminate on start-up, certainly not while driving. The bulb appears good with an intact filament. I did notice an unused connection. Can I easily connect it on my current harness?
    Thanks again
  1. WTB 1969 911S Wiring Harness For MFI Pump
    By 69S-S/R in forum For Sale: 911 Parts
    Last Post: 06-23-2012, 05:26 PM
  2. FS wiring harness '68 911 rhd
    By chasg in forum For Sale: 911 Parts
    Last Post: 12-26-2010, 07:53 PM
  3. Wiring harness differences, '65 912 vs '67 911S
    By 67 911S in forum General Info
    Last Post: 12-04-2008, 05:36 PM
  4. Wiring harness
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 09-03-2007, 06:28 AM
