Results 1 to 2 of 2
Thread: Removing Paint From the Inside of a Ducktail?
    Aug 2006
    Chicago area
    Who has knowledge or experience doing this? I would like to remove the paint from a factory ducktail without damaging the fiberglass material. The outside is easy - sand, sand, sand. But what to do about the layers of paint on the inside?
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Scott,
    When I first got my used factory tail I took it to a friend and had the whole thing 'walnut blasted'.... seemed to do the trick.
    Hope this helps
  1. 1966 911 inside door paint
    By bobm in forum Technical Info
    Last Post: 02-11-2013, 02:33 PM
  2. SN # 11850038- Removing original paint: best media to use?
    By johnchodgson in forum Technical Info
    Last Post: 05-09-2011, 01:55 PM
  3. removing paint from fuchs
    By ferry58 in forum Technical Info
    Last Post: 09-15-2009, 05:25 PM
  4. Removing paint from original vynil
    By Ralfy in forum Technical Info
    Last Post: 06-06-2009, 09:48 AM
  5. Removing paint tag assistance
    By WM711 in forum General Info
    Last Post: 08-11-2007, 09:58 AM
