Thread: significance of "build number"?
    can anyone please advise if there is any significance to the build number on my '70S?
    1000167
    Cheers
    Mitchell
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    not really by itself, but it is a good cross check against a chassis number (with the combination/ match only really known by Porsche) especially for high value cars like RS's that can be forged / cloned
    apart from that it says it is a 911 (1); coupe (0); from 1970 model year (0); and is the 167th coupe of any sort built that model year by Porsche (I am not sure but I have a memory that Karmann cars had their own identifier in this series as well - a 2 instead of the 0? with targa's having a 1 -someone please chime in and confirm or otherwise)
    that would place it as an early, possibly September 1969, build and the "S" chassis number is likely to be well short of #167 given that E's and T's were also being built
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Oct 2008
    Burford, ON, Canada
    I believe that Hugh is correct. The body number seems to be a bodyshop control number that identifies the sequence in which the bodies were built. It may have been used for daily production statistics and for defining when changes were made. The factory has wisely made little known of these numbers, and does use them to help confirm the authenticity of a VIN. The factory will not tell you what the body number is for a particular VIN, but will confirm if the two numbers match their records.
  1. Porsche 911 "80's" build
    By obrut in forum Other Porsche Passions
    Last Post: 09-25-2013, 06:49 PM
  2. "PS Autoart *BUILD PROGRESS - NEW PICS*"
    By serie1926 in forum Other Porsche Passions
    Last Post: 03-17-2012, 08:45 AM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 03-09-2012, 07:53 PM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
