Thread: exhaust backfire at idle
    Before service, no backfire.
    After adjusting valves, installing pertronix, setting timing at 2 degrees btc at 900 idle and 30 degrees at 6,000, installing new plugs, I now have periodic backfire through the exhaust at idle.
    The webers were not touched. The exhaust was not touched.
    Anyone have any ideas?
    Thanks in advance,
    Rob
    356Robo
    64 C Coupe #218448(sold)
    70T Targa #9110110416(sold)
    Sounds like a plugged or lean idle jet.
    the idle air screws probably need to be dialed, sometimes I can do this on my own (memorize slot positions before you touch it) and sometimes I take it to jeff at randall aase.Steve
    66S and Steve,
    Thank you for your responses, but I don't think its a carb issue. I did not touch the carbs.
    All I did was:
    Adjust valves
    Replace plugs
    Install Pertronix
    Set timing at 2 degress after tdc @ idle and 30 degrees @ 6,000 rpm
    Today, I'll check all wiring connections and make sure cap and rotor are aligned properly.
    Rob
    356Robo
    I found it. A couple of plug wires were loose at the distributor, duh.
    Checked all of the connections, warmed her up and went for a drive.
    There's nothing like the sound and feel of a freshly tuned 911.
    Rob
    356Robo
  1. MFI Backfire
    By 50/50 in forum Technical Info
    Last Post: 10-15-2013, 11:29 AM
  2. Exhaust Experts Unite - need help for racing exhaust !!!
    By RPMClassic in forum Technical Info
    Last Post: 09-06-2006, 06:06 PM
  3. High Idle
    By 72targa in forum Technical Info
    Last Post: 05-30-2006, 10:42 AM
  4. Why is my new speed switch causing backfire?
    By jayzoll in forum Technical Info
    Last Post: 05-27-2004, 03:33 PM
  5. Bad Backfire
    By cvfncrew in forum Technical Info
    Last Post: 10-10-2003, 07:12 PM
