Thread: Bouncing speedo needle help
    May 2010
    Louisville Ky
    After fixing the odometer on my 70 911e, the speedometer needle started bouncing at take off and up to 30mph, then smooths out.
    The needle functioned properly before the odometer fix.
    Using a drill at the disconnected gauge the needle is fine, no bouncing.
    Using a drill on the cable at the transmission disconnect the needle bounces.
    Is replacing the cable the fix or could it be something simpler? (I hope)
    Bud
    Nov 2003
    Northern FL
    Mine did the same. I found the cable was loose on the end going into the speedo. Even though I thought it was tight when I put in my new cable, it was slightly misaligned and tightening it got it recentered. Should be easier on a 70; on my 69 I had to disassemble air system because of 356 style brackets which hold the instruments in place from the back. Could also be on the drive side. Good luck.
    Jim Lonsdale
    Member #80
    60 356 Coupe (First Car $400!)
    61 356 Coupe (Gone)
    62 356 Cabriolet (Gone)
    69 911 S
    70 914-6 (Gone)
    70 911S (Gone)
    May 2010
    Louisville Ky
    That was it!
    Tightened it at the speedo ever so slightly.
    Way easier than replacing the cable.
    Many thanks greens!
  1. Speedometer and Tachometer needle sticking.
    By bliebler in forum Technical Info
    Last Post: 12-27-2013, 07:05 AM
  2. Nadella Half Shaft Needle Bearing
    By Brad Davis in forum Technical Info
    Last Post: 07-03-2013, 04:55 AM
  3. 1965 911 needle in haystack question
    By JBQuick in forum General Info
    Last Post: 02-25-2013, 01:27 PM
  4. Weber Needle Valve Mystery
    By 356robo in forum Technical Info
    Last Post: 02-26-2011, 03:57 PM
  5. WEBER Needle Valve/Float position help
    By mjmoran in forum Technical Info
    Last Post: 11-13-2003, 12:33 PM
