Results 1 to 7 of 7
Thread: Targa emblem (and hoop?) removal
    I'm pretty sure that the targa emblem is held on by speed nuts like the decklid 911_ and PORSCHE lettering. I thus assume that you need to remove the hoop to access the speed nuts - and remove the targa emblem. Can anyone confirm this is correct?
    Also, does anyone have a good 'how-to' guide for the hoop removal? Can it be done without disturbing the targa panel seals etc?
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    Shane Rudd (Sydney Australia - Oz delivered T )
    Jan 2005
    uh oh.....#4
    Jul 2008
    near Ottawa, ON,canada
    both lwb ans swb targa
    since both targa bar cover are interchangeable , the removal is the same
    the script is held by 2 speed nut as suspected
    you will have to remove the seal in front of the targa bar to remove it , there is a bunch of small phillips screw that hold s it in
    the hidden one are in the fender well , usually 8mm bolts covered in muck and grim , if they are stuck , use a dremel and slice the screw off , dont force it , if it break you will neeed a need cover as a stud is welded on the cover and welding a new usually result in a blue mark on the metal
    freez
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    Hoop Removal
    Don't do it unless you HAVE too. You have to most likely destroy the expensive seal, some screws are likely to be rusted, etc. etc.
    You also have bolt heads with nuts under the the rear fenders, they are likely to be rusty and may break off....
    -Allen-
    Senior Member larwik's Avatar
    Dec 2003
    Los Angeles, Ca
    I agree with Allen...when I replaced my "Targa" emblems...I measured carefully the stud location on the "new" emblem...marked and drilled the "old" emblem carefully from out side...was lucky and hit the stud close enough to punch in the remains of the stud with the acorn-nut still attached and just let them fall down into the "abyss"...clean off the surface and attach the new emblem with a little "drop" of Epoxy...worst scenario is that they'll fall off...big deal!.../ Lars...
    Lars Wikblad...
    Early 911 "S" Registry # 527
    "R" Gruppe # 314
    Quote Originally Posted by larwik View Post
    That is the way to do it!!! You can just break off the old emblem.
    -Allen-
    Thanks guys - I think I will go with the no-hoop-removal method.
    Less chance of opening up Pandora's box simply to change the emblem from black to gold...
    Cheers, Ryan
  1. Shoulder belt removal from '71 Targa
    By TZombek in forum Technical Info
    Last Post: 01-27-2013, 04:36 AM
  2. vintage roll bar main hoop radius?
    By keith in forum General Info
    Last Post: 10-02-2008, 06:13 AM
  3. help! removal of rear window Targa
    By EARLY911ZOO in forum Technical Info
    Last Post: 07-10-2008, 06:20 AM
  4. 72 targa hoop refurb, Rs flares
    By 911kiwi in forum Technical Info
    Last Post: 07-20-2006, 08:08 PM
  5. Targa Rear Window Removal
    By eaglenav1 in forum Technical Info
    Last Post: 05-30-2001, 12:24 PM
