Results 1 to 10 of 17
Thread: what to adjust to keep hood from constantly opening?
    My hood keeps unlatching during driving- thankfully, it still requires to pull up that lever to open completely otherwise I'd have some *really* undesirable situations arise while driving- anything I can adjust to correct this issue? I don't want to tinker with it and then not be able to open it- any suggestions would be appreciated.
    Marco
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Sep 2006
    Maryland
    You need to tighten the center post, unscrew the nut holding it in place, a few turns, then screw in the post. Do this in small increments until it holds, then lock the post in-place re-tighten the nut. Trial and error.
    Rob Abbott
    Thanks Rob- I'll give it a try
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Also, never disregard a obvious...
    Be sure the latch plate retracts freely on its spring. Sometimes the plate gets so much grime in and around it, it doesn't return anymore. Some W-D40 a exercising the latch plate usually does the trick.
    Cheers
    Dec 2002
    Birmingham, AL
    I had this problem once. It turns out the latch releases not only when the cable is pulled but also if the cable is too loose. This is apparently intended to release the hood in the event the cable breaks. In my case the cable was too loose. It took some trial and error to find that "sweet spot". I suppose wear on the latch parts adds to the problem.
    BillM
    Apr 2003
    Portland, OR
    I had a similar problem. I lube the assembly with TriFlow every 6 months now and no problems!
    Harry
    Member #789
    2009 MB C300
    Dec 2004
    check "rubber snubbers" too
    The rubber hood stops may be to loose as well. They may need a half turn to keep good pressure on the latch.
    I second and third the comments on cleaning and lubing the latch. Did the trick for me.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Quote Originally Posted by super9064 View Post
    I had a problem with my hood unlatching too but found that I had to screw the centre post out (ie loosen it, rather than tighten it as detailed in the post above). I simply loosed it about a quarter of a turn, drove it and then then checked if it opened again. Repated this until the hood stayed shut. Interestingly the hood now latches more easily and I canfeel it engage the latch properly now. Have now driven about 500km since adjusting it, inclluding a day at Eastern Creek, and it has not opened on its own.
    Cheers
    Graeme
    Cheers
    Graeme
    993C4S
    911 '73RS recreation
    yep -I had a huge problem with my 912 with the bonnet. I lost days of my life fiddling with it and finally got it right. You may need a few stiff drinks after you've tinkered with it. It's definately one of 2 things - the bolt length - or the cable adjustment to the latch. I worked out that my bonnet was actually twisted. Also the alignment of the bonnet is crucial - to get the bolt in the exact centre of the hole or the bonnet flexes.
    Also it helps if you have a bumpy road not far away that you can test the latch out to see if it pops!
    The best of good luck to all tinkering on this matter. Be patient and work in small adjustments.
    Quote Originally Posted by Gman993 View Post
    Cheers
    Graeme
    Graeme,
    If this is the case, you probably need to twist the rubber snubbers in a few turns instead of loosening the post. The goal is good fit on the hood with a slight amount of downward give. If the latch tightens down against the snubbers, it will pop open while cornering
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
  1. Did factory use shims to adjust hood and frunk lids?
    By Mark Wilson in forum Technical Info
    Last Post: 10-01-2013, 10:17 AM
  2. Problem: constantly have to log in
    By Allen Henderson in forum General Info
    Last Post: 02-01-2011, 07:00 AM
  3. Check Measure Adjust
    By typ901 in forum For Sale: 911 Parts
    Last Post: 04-29-2007, 05:19 PM
  4. FS: 911 SWB timing & valve adjust sticker
    Last Post: 02-28-2007, 06:39 AM
  5. First valve adjust done! Only 6 hours...
    By berettafan in forum Technical Info
    Last Post: 11-27-2006, 02:52 PM
