Thread: CIS to Weber conversion question...
    Guys,
    I am gathering up the last bits to put 40 IDAs on my 2.7 CIS and I cant seem to find in the manuals the throttle bracket part that mounts to the front of the engine near the bell housing area for the throttle linkage. I am trying to figure out if the CIS one will work with the Webers or do I need to start looking for one?
    Thanks in advance!
    The manifold has a shaft in it that the bell crank mounts on. You would use a standard bell crank such as would have been used on a early carbureted 911.
    Sep 2006
    Eagle, Idaho
    Happened to have my engine out yesterday for some final mechanical "sorting " details and remembered this thread......please see picture of the bell-crank and the connection between throttle linkage from gas pedal to engine-mounted portion of carb linkage. ( Mine are PMO manifolds, but the shaft Mayo's talking about should be in same location and dimensions on OEM manifold ).
  1. Weber 40 IDS question
    By 68S_SK2 in forum Technical Info
    Last Post: 09-24-2017, 08:01 AM
  2. Power brake conversion / de-conversion (1973 2.4E)
    By obrut in forum Technical Info
    Last Post: 12-13-2012, 02:18 AM
  3. Weber IDTP to IDA conversion
    By 1QuickS in forum Technical Info
    Last Post: 09-27-2012, 05:32 PM
  4. Help! - Weber question
    By gilbert911 in forum General Info
    Last Post: 12-06-2006, 02:25 AM
  5. t to e conversion question
    By tryan in forum Technical Info
    Last Post: 12-23-2002, 08:39 AM
