Thread: How do you tell if a car has matching #s
    Mar 2005
    Is a COA the only way to determine if a car has matching numbers?
    Oct 2008
    Burford, ON, Canada
    Other than the Kardex on which the COA is based, there is no other way of being certain.
    The original delivery documents and service folder normally have the engine no. also.
    I just ring the local Porsche dealer with the VIN and, whilst they will not tell you the engine no., they will advise if the engine no. you give them is the original one or not. They also have the options etc on file also.
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
    Seattle WA
    If you're a member of the early S Registry, you get a copy of the Registry every year. With that Registry in hand you should be able to tell if (if you're looking at an S) the engine/chassis that you are looking at fit within the range of other engine/chassis numbers in the database.
    e
  1. 1969 911s value matching numbers vs non matching
    By frankmar in forum General Info
    Last Post: 02-26-2015, 09:53 AM
  2. Is it a matching # S?
    By john26 in forum General Info
    Last Post: 08-10-2012, 12:27 AM
  3. WTD 911 S 69/70 must be matching
    By froggy in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 03-13-2011, 09:46 AM
  4. FS: '68 S SWT Matching #'s
    By popowitz in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 08-25-2010, 06:29 AM
  5. Value of 72S with non matching #
    By dmcummins in forum General Info
    Last Post: 07-29-2004, 06:24 AM
