Results 1 to 8 of 8
Thread: Wtb - 901 lsd
    Wtb - 901 lsd
    Guys I have a very nice rally geared 901 5spd box that I would like an LSD for. Anybody have one they want to get rid of? Are there many after market alternatives? Perhaps something from VW?
    Feb 2007
    San Diego
    VW LSDs are homemade - simply weld the spider gears together on your differential, then don't drive on the street too much.
    I don't think any VW trans parts fit the 901 box.
    If the trans is aluminium Guard Transmission has a beautiful unit with modern internals and will fit with eather type drive flange. If it is mag, Guard again. 1 888 89 Gears. Gordon
    Oct 2008
    Burford, ON, Canada
    What version of the gearbox do you have? Type & serial # would help.
    At one time I had a 904 LSD that fit an early 901 case, but there were other versions.
    I have a 901/16 with a rally gear set in addition to the short R&P. It was a race box many years ago. Since I will be on some icy roads in my near future I think an LSD would be nice. I am not planning on serious track use at all but perhaps a time trial here and there. So an original would be nice if they are around and not too pricey.
    GT makes a great diff but it is WAY more than I need for this application. I was hoping for a cheaper option...
    Stock wont be cheaper.S
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    Quote Originally Posted by joeblow View Post
    Is it not a 902/16 with a 6:29 ring and pinion and what gears are in it? Not aware of a 901/16.
    Quote Originally Posted by 911s55 View Post
    Yep, typing to fast, 902/16, I have a gear sheet somewhere for it. It was rather tight gear split up top with a long 1st starting things off.
