Results 1 to 10 of 14
Thread: Installing Recaro sport seats
    Senior Member 72911E's Avatar
    Jul 2006
    London / Fort Lauderdale
    I took out the original standard seats today and was going to put in the Recaro sport seats I picked up a couple of years ago. I do have the mountung rails for the sports seats.
    Couple of questions
    1) Do they mount in the same place as the originals?
    2) Where does the seat belt fix?
    3) I dropped one of the bolts, what size bolts are they The bolts near the transmission tunnel are longer that the bolts that fix seat that is closer to door.
    Any help much appreciated.
    Derek
    '72 911E 2.4 Coupe RHD - Blue
    Jan 2003
    UK
    Derek - do you have the tilting bases for the sport seats ?
    The sport seats bolt (via 4 M8 hex bolts) to the tilting bases which, in turn, bolt to the floor by means of M6 'cheese head' machine screws.
    The seatbelt receiver bolts to the tilting base.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Jul 2006
    Thanks Andy. Yes I have the tilting basis.
    Where in London are you Andy. I am in SW London close to Putney.
    Cheers
    Derek
    Jan 2003
    UK
    Need to change my profile Derek as I've now moved to the Midlands ... know SW London very well though as I grew up there (originally Putney).
    You should come along to the DDK SW monthly meets at the Fairmile (between Esher & Cobham) - I think the next one's Wed of next week.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Jul 2006
    Cheers Andy. Will try and get along there one evening .........need to get my seats in first
    Hi,
    Just in case a few pics help.
    These are 73 frames/seats (twin locking frames)
    These are 72 frames
    HTH
    Alan
    Yes they do bolt into the same floor mounting holes but require a bit longer screw (not sure of the length) other experts will know that I am sure. Do a quick run through of holes with tap to make life easy.
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Jul 2006
    Thanks. That would make sense that the original screws would not work.
    Anyone know what length screw/bolt I need?
    Andy, mentioned size M6 but what length? Just picked up some M6 bolts today but not sure if long enough.
    Derek
    Hi,
    They are from memory 15mm long. They are also socket head M6, or also known as pan head. Here is another pic. This is a first 500 RHD RS. You can see the mounting bolts, but they should be zinc "yellow".
    HTH
    Alan
    Jul 2006
    Great, thanks Alan.
    The M6 bolts that were in for the original seats were 20mm. So I think I need 25mm or 30mm to fit the sport seats.
    For the seat belt buckle to attach to the seat base - Any particular bolts I need here?
    Size and dimensions would be really helpful, want to try and get the seats in asap.
    cheers
    Derek
  1. Replies: 1
    Last Post: 07-13-2014, 05:50 AM
  2. Recaro Sport S seats .... Scheel 400 Rallye Seats/tilt slides
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 08-06-2012, 02:42 PM
  3. '72 Recaro Sport Seats
    By brseidel in forum For Sale: 911 Parts
    Last Post: 02-28-2009, 11:09 PM
  4. Replies: 3
    Last Post: 06-24-2008, 02:56 AM
  5. Replies: 1
    Last Post: 09-28-2006, 10:17 PM
