Thread: Front brake locking up
    1973 911 # 58 Francois Duval's Avatar
    Dec 2003
    Montreal , Canada
    Hi , I just finished a restoration on a 1970 911 T
    I have a problem with the right front wheel always locking up under braking.!
    The car has SC calipers in front !
    I changed a couple brake lines in the restoration process and put in the stainless small lines to the calipers.......... Does the lenght of the lines have an impact on braking pressure ?
    All four calipers are in good condition and operate correctly ???
    Any leads appreciated........!
    Francois
    Could be a corner-balance/alignment issue.
    Does the car pull to one side under braking, before it locks up? If so, then the left front caliper may not be braking properly.
    Quote Originally Posted by Francois Duval View Post
    Does the lenght of the lines have an impact on braking pressure ? Francois
    Nope, should all be OK unless you have 'kinked' a line in which case it would pull badly when you brake.
    The length of lines is not a significant issue. I always think it is a bit more elegant to have them similar lengths but its not essential.
    Dec 2003
    Montreal , Canada
    Brakes
    Hi Max, thanks, yes the car is just out of the alignment shop, I also noticed the
    car is not straight, rear right side is a bit higher than the left side....
    So much for corner balancing.......... I will have this corrected and see
    if it improves braking......
    Francois
    Dec 2003
    Montreal , Canada
    Brakes
    Hi Chris,,,,,,,, I did bleed the brake lines and get a good sprinkle out when I open the bleeders............ ! If a line was kinked would`nt it be showing there ??
    I will get the car out again this evening and look for any pulling ! Thanks
    Francois
    Francois
    When you get a proper corner-balance using scales, ask for equal front weights. Also, remember to put your weight in the driver seat and some fuel in the tank (or whatever configuration of passenger or luggage load you normally drive with).
    Some people prefer a corner-balance with equal diagonal weights for more consistent cornering right/left but the equal front weights makes for better braking. You cannot usually get both weight splits equal.
  1. FS: S Front Brake Calipers
    By Lola in forum For Sale: 911 Parts
    Last Post: 02-27-2014, 07:32 AM
  2. Locking front hood release
    By W6CZ in forum Technical Info
    Last Post: 06-10-2009, 07:24 AM
  3. New front brake rotors SWB
    By 67Porsche911S in forum Technical Info
    Last Post: 03-03-2009, 04:58 AM
  4. WTB: Front suspension/brake set-up
    By gruen911 in forum For Sale: 911 Parts
    Last Post: 06-28-2007, 06:53 AM
  5. front hood locking mechanism
    Last Post: 03-05-2007, 05:38 AM
