Thread: FS: Vintage Oil Pressure Relief Valve Replicas
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Looking for that hard to find oil pressure relief valve for your RSR tribute? This is the very best replica valve we've found.
    This is a modern alternative of the factory Oil Pressure Relief Valve (Porsche pn #901.107.285.20) The "Uberdruckventil". This model uses the cap itself to set the pressure. Simply screw the cap to the desired pressure setting and you're good to go (comes pre-set at 75lbs.) The cap is hand machined to match the original valve in appearance. It has the correct 26x1.5 threads and is dimensionally as close as can be. This unit is made from a commercially produced valve , which helps keep the cost lower (there is an RSR copy that also looks correct, but is non adjustable and €900.00 euro’s!!)
    There is a very limited number of these valves available at this price. Asking $595.00
    http://www.pmbperformance.com/catalo...34/8176414.htm
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Really nice Eric!!!!
    Dec 2002
    Sandy, Utah
    Thanks Oliver... discounts for multiples.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Relief valve
    Is this the valve that attaches to the 74 RSR oil tank neck ? If so how much for 2 ? Thanks, Steve sschmidt@honesteng.com 714-319-4593
    Dec 2002
    Sandy, Utah
    It is Steve... I'll send you an e-mail.
    E.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
  1. Oil pressure relief mods and measurements ('67)
    Last Post: 01-07-2014, 01:30 PM
  2. Replies: 2
    Last Post: 04-22-2013, 06:16 PM
  3. Replies: 0
    Last Post: 02-11-2013, 10:19 PM
  4. RSR oil pressure relief valve
    By Wild Bill in forum Technical Info
    Last Post: 12-21-2010, 11:50 AM
  5. FS: 2.8RSR Oil Pressure Relief Valve
    By PJenkins in forum For Sale: 911 Parts
    Last Post: 06-25-2008, 11:53 AM
