All parts are in good working condition. Pictures on request. Prices do not include shipping.
1) 2.4 Liter Mag Engine Case 911/51 SN-6131319 PN-901.101.102.7R/901.101.101.5R
with Head Studs and Case Bolts (Original Bore) $200
2) Behr Engine Oil Cooler PN-911.107.041.00 . . . SOLD
3) Engine Oil Pump (3 Bar) with shaft $20
4) 911T Cams $20
5) Intermediate Shaft with ‘0’ gear $50
6) Original Oil Sump Cover with Drain Plug and Screen $50
7) Thermostat $10
8) Cylinder Cooling Tin $40
9) Oil Lines Left/Right $10
10) Cam Chain Tensioners Left/Right with Safety Collars $20
11) Oil Temp and Pressure Sending Unit $10 (both)
12) Engine Tin Left and Right Side (Valve Cover) for MFI $20
13) Engine Tin Left and Right Side (Valve Cover) for Non-MFI $20 . . . PENDING
14) Engine Tin Rear Cover for MFI Drive Gear $20
15) Engine Tin Rear Cover for Non-MFI $20 . . . PENDING
16) Engine Tin Front Cover $20 . . . PENDING
17) Engine Yoke with Muffler Bracket $30
18) Engine Mount Cross Bar $30
19) Engine Shroud Heater Plates Left and Right . . . SOLD
Thanks for looking.
