Anyone have a trick for cleaning a headliner? Mine is nice but
stained/yellowing in places. I thought of trying a diluted bleach solution
or upholstery cleaner of some sort but don't want to do any harm.
Alan Domme
Austin, TX
'68 912 coupe
'16 VW Golf R
Early 911S Registry #1361
912 Registry
clean it first with soap and water, then try mr clean magic eraser...
another option try woolite he (high efficency) diluted with water with a 20:1 ratio
Harry Hoffman
356 Registry Member #36691
I had excellent results with Scrubs-in-a-Bucket hand cleaning towels.
I have tried several solutions to remove the stains - CLR (Calcium, Lime, Rust), Iron Out, and Bleach. I first used a simple terry towel with each of the solutions and rubbed gently. I am not sure which one worked the best, but it did improve the yellow stains somewhat. Personally, I thought that a careful application of bleach would do the trick, but the OTC bleach available to consumers today is just not a very strong solution IMO. I even tried to bleach the hard water stains in some bathroom grout to no avail (and I have used this successfully in the past - that is why I think the concetration has changed in the past 10 years or so).
In the end, I just used a cleaning product from my detail shop and the sponge/scotchbrite pads you get for the kitchen. I use the green scotchbrite side and a cleaning solution. Seemed to do the best for me, but still did not fully remove the stains. Good luck.
Scott H.
1969 Coupe LtWt
1973.5 911T
An alternative, took me a looooooong time to locate but I found a vinyl dye in a rattle can on web that matched up VERY close to new headliner from Autobaun. Just finished ivory side of visor's and they look great agains't new headliner.
Early 911S member #166
Thanks for all the suggestions. I've only tried 409 in the past and didn't want to get too aggressive without consulting others. Sounds like the headliner will tolerate more than I threw at it.
Alan Domme
Austin, TX
'68 912 coupe
'16 VW Golf R
912 Registry
