It fit very well, but as John said, the texture was not spot on.
E911SR & RGRUPPE
'73 S Coupe #306
I bought the latest Porsche Classic dash recently. I was not impressed and returned it. Besides the odd grille choice, I thought the fitment was worse than the Lakewell (Carpoint) dash and the fitment around the speaker grille was terrible. Someone else posted that they liked theirs but even in their photo the gaps around the speaker grille looked way off to me.
You might try posting a WTB ad for an old version Lakewell dash. I did the same a few months back, got lucky and was able to buy one for my current restoration and a backup to keep on the shelf. But I paid a pretty penny for them.
Does anyone know when the Lakewell/Carpoint dash changed for the worse? I have a carpoint sitting in the garage but afraid it may be the "worse" version.
69 911S #1379
65 356 SC #130757
There's always an alternative . . .
http://www.early911sregistry.org/for...-911-Dashboard
Ah it is pretty easy to drill out the corner voids for the original look. The template is staring you right in the face. Use the grill to make a paper template for the corners. Make sure it is few rows more then needed so you can line it up properly on the grill. Punch out the paper and transfer it to a thin plastic with spray paint. Drill out the plastic with a drill press. Center on the grill using the overlapping holes. I used spare drills through the template into to hold it in place with the extra holes. I used a 3.5 mm for pilot holes and 4.1 to finish. Do not drill too deep. I clamped the template with various C clamps; not too tight. It came out great. I've also done one by spraying directly onto the grill. No hard template. Then free hand drilled the holes; more fussy cause you need a steady hand. Either way some of the holes were a little ragged so I finished with a fine rat tail file passed through a couple of times top to bottom. The free hand way also came out very nicely. It is time consuming but easy.
58 speedster
66 912
67S
73S
97 VW eurovan
1132 honda snowblower
member Jackson Hole Ski Club
