Thread: 30mm Venturis in Webers in stock '68 911
    Senior Member 68911USA's Avatar
    Jan 2009
    Salisbury, MD
    I am in the process of installing a K&N Watershield kit to my otherwise stock 1968 911. (I just love the sound, that's all.) I looked down the throats and I can clearly see the markings that indicate that I have 30mm venturis in the Webers, but I thought the stock size was smaller. I don't think anything on the engine of this car had ever been messed with- all the cylinders, senders, etc. all have date codes that correspond with the 10/67 production date, so I can't see why someone would put "bigger" pieces inside the carbs without changing the rest. (It did have a really old sport muffler on it, though- maybe it was meant to complement that.) I'll have to pull the carbs off to confirm the jet sizes etc., but would a 30mm venturi be a normal thing to upgrade to with a performance muffler? The carbs look like they have not been opened up in a long time, still have original banjo fittings and lines on them!
    1968 Porsche 911 #11830133 (2009- 2012)
    1968 Porsche 911T #11820522 (1997-2007)
    Registry Member #1536
    Hagerty Insurance Guy
    Missing my Porsche. Need to find another SWB project!
    Current cars:
    1918 Willys-Overland Model 90BT
    1966 Sunbeam Tiger Mk1a
    1977 Chevrolet Suburban C20 "Trailering Special"
    1983 Ferrari 308 GTS Quattrovalvole
    1992 RHD Toyota Century
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    The 30 mm venturi is stock original on your 130 hp 911.
    The 911T (110 hp) engine had 27 mm venturi and the 911S (160 hp) engine had 32 mm venturi.
    Best,
    Grady
    Jan 2009
    Salisbury, MD
    Thanks, Grady! Hope the fires didn't affect you.
    Current cars:
    Jan 2009
    Salisbury, MD
    Here's the chart I initially looked at, pulled from the web. Shows 2.0 at 27mm, and the 2.0E at 30mm. This is why I thought it was hot rodded in some fashion- wrong info, obviously! Thanks again, Grady.
    Engine Size & Cam Main Venturi Main Air Idle Emulsion Tubes Notes
    2.0L 27 110 185 50 F2 Porsche Factory
    2.0E 30 125 180 55 F26
    2.0S 32 130 180 55 F3
    2.2E 30 125 180 55 F26
    2.2T 30 125 180 55 F26
    2.2S 32 130 180 55 F3
    2.4T 30 130 180 60 F26
    2.4E 32 135 180 55 F26
    2.4S 32 135 180 60 F3
    2.4 CIS T 30 130 180 55 F26,F3
    2.7 CIS 32 135 180 55 F26
    2.7 CIS w/Tall AV's 34 140 180 60 F3
    2.7 E, S 34 145 180 60 F3
    2.7 E, S w/ Tall AV's 36 155 175 60 F3
    Current cars:
  1. WTB: Cornpanzer's 30mm Extended Hub
    By Stretch32 in forum For Sale: 911 Parts
    Last Post: 07-07-2013, 04:33 AM
  2. FS: New Rear T-Bars 911 65-86' 30mm
    By jhora in forum For Sale: 911 Parts
    Last Post: 09-13-2009, 07:49 AM
  3. Fuel delivery set-up for stock Webers
    By 911TES in forum Technical Info
    Last Post: 08-20-2009, 09:49 AM
  4. Looking for some 30mm venturis for Solex P1
    By Baron in forum For Sale: 911 Parts
    Last Post: 04-06-2007, 07:37 PM
  5. WTB: 30mm T-bars
    By Homemade 911 in forum General Info
    Last Post: 04-15-2004, 12:19 PM
