Thread: SWB rubber fender washer dimensions
    What are the dimensions of the rectangular rubber washers that go underneath the rectangular plates under the fender screws on an SWB?
    I recall that they are 3/4" wide but was wondering if someone could confirm.
    Thanks!
    Rubber fender washer
    The metal plate is 18.5 x 25.5 mm (Approximately 3/4" x 1 "), The rubber was that size or a little larger - or appeared to be a little larger after it was squeezed in place for years.....
    hth
    Bob
    Early S Reg #370
    Bob, that is an enormous help. I need to fabricate some rubber washers to go under the re-plated steel washers and install them with the Kamax screws BEFORE the final schutz of the trunk. Naturally I am 100 miles from my parts when the time comes to order these things. Thanks!
    Atlanta, GA
    Can you post a pic of these rubber square washers? My 68 did not have rubber under the clips. It did have round fiber washers under the bolt heads that I think were red in color. I am sure my fenders were never off the car. We're the 66's different? Thanks
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    I'll try to snap a pic for you. The Stoddard kit has round fiber washers.
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by merbesfield View Post
    My '68 also has the round fiber washers. I don't think the square ones lasted all the way through the SWB model production run. My '67S had them, but not the '68.
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. Replies: 6
    Last Post: 01-12-2024, 07:58 AM
  2. Replies: 29
    Last Post: 11-23-2019, 04:41 PM
  3. fender wheel arche trim RUBBER
    By Marek in forum Technical Info
    Last Post: 07-07-2011, 12:32 PM
  4. Replies: 24
    Last Post: 04-04-2008, 02:26 PM
  5. New Rubber Covers for Blinker and W/Washer
    By daepp in forum General Info
    Last Post: 08-31-2007, 12:43 PM
