Thread: electric Fuel pump for MFi mounted
    Anyone have pics showing where and how the electric fuel pump is bolted onto the chassis for year 1970? Thanks!
    Pump location
    This is what I found. However is there a bracket where the pump strapped in some fashion.
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Search Pelican on my name and MFI.
    I posted all the images for this installation.
    Best,
    Grady
    fuel Pump Mounting
    Thanks Grady! This is what I found so far from your post.
    Pay to play Schiefer's Avatar
    Jun 2008
    Norway
    Guess you got what you needed from Grady. Attaching a few more pics. I forgot to take a picture, but think I remember there was a small bracket behind the pump.
    Grady: Is that a replacement pump you have used??
    Best, Radmund
    S-Reg #1382
    67S Lavender
    Sep 2004
    Carlo,
    One error the above installation has; the pump is mounted to the tub sheet metal. This makes for an obnoxious ‘buzz’ all the time.
    With a steel front cross member, the ’69-’70 pump mount clamps onto the front cross member tube. This is the best, least invasive mod. I suspect those parts are difficult to find.
    A good solution is to weld two tabs on the steel tube for the rear pump mount (’71-’75). This mount is commonly thrown away so there should be many available ‘almost free’.
    This allows you to use the rubber vibration isolators while keeping it easy to service the pump and hoses.
    With the aluminum cross member (’74->), there is more room. There is enough room for an aluminum in-line filter. This keeps more of the fuel components in this nice cool location. The fuel pump (and filter) must have vibration isolation to mute the noise. The pump and filter can use the above mount. Be sure to add a small braided ground strap around the rubber pump isolators to prevent RFI.
    Please post the Pelican links you used.
    Best,
    Grady
  1. FS: Used MFI Fuel Pump - Electric
    Last Post: 09-04-2013, 09:34 AM
  2. FS - Bosch electric fuel pump for MFI
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 09-27-2012, 06:49 PM
  3. NOS New In Box German MFI Electric Fuel Pump
    Last Post: 11-22-2011, 11:12 PM
  4. FS- Hardi Electric Fuel Pump
    By 72tii in forum For Sale: 911 Parts
    Last Post: 05-21-2009, 03:52 AM
  5. FS: MFI Fuel Filter Console and Electric Fuel Pump
    Last Post: 07-28-2008, 07:10 AM
