Results 1 to 1 of 1
Thread: 912 to 911 Engine Conversion
    Senior Member 72tii's Avatar
    Nov 2004
    Bedford, TX
    Selling this 912 to 911 engine conversion kit for a friend in Fort Worth, Texas. He bought the engine as a 914/6 conversion that never happened to get the 914/6 parts, i.e. heat exchangers, sheet metal, motor mount, etc.
    This left a 1969 911T # 6196156 (901/16--build number 21788) with no sheet metal or exhaust. Supplied with powder coated sheet metal and air cleaner assembly. Sand blasted and painted muffler and heat exchangers. Bischoff muffler with aftermarket heat exchangers in very good condition.
    Heads have been torqued and the valves adjusted. Installed Turbo valve covers, replaced oil return tubes and sump plate. Mileage is unknown, but it appears to be low with very good oil pressure and leakdown numbers:
    1. 5%
    2. 4%
    3. 4%
    4. 5%
    5. 3%
    6. 4%
    Marelli distributor replaced with a modified later Bosch unit with Pertronix and Bosch black coil.
    Fan and blower housing have been cleaned and early wiring harness fabricated. Alternator and regulator test good.
    Zenith carbs were disassembled, cleaned, replaced accelerator pump diaphragms, zinc plated linkage and related parts. The enrichment circuit has been correctly deleted.
    Oil tank was professionally cleaned by Metal Rehab and painted, filler neck zinc plated. New oil filter, scavenge hose is new, S hose is used but in good shape.
    Motor mount brackets are OEM new from Porsche, rubber motor mounts are new. Has proper cupped washers and bolts.
    Includes everything you would need but an electric fuel pump and the breather hoses from the oil tank to the engine & air cleaner.
    $4700 OBO for everything picked up in Fort Worth. $1200 extra for turn-key installation.
    1968 911 #11830241
    Early S Registry #810
    R Gruppe #461
  1. 3.2 conversion into 71
    By Sundevil64 in forum Technical Info
    Last Post: 10-13-2013, 07:14 AM
  2. 3.2 Conversion ECU
    By CidTito in forum Technical Info
    Last Post: 07-28-2013, 03:47 AM
  3. Power brake conversion / de-conversion (1973 2.4E)
    By obrut in forum Technical Info
    Last Post: 12-13-2012, 02:18 AM
  4. 911 to 912 conversion
    By ren915 in forum General Info
    Last Post: 03-15-2012, 07:49 PM
  5. FS: 1971 Porsche 911 RS Conversion with 3.2 Carrera Engine...Well Sorted!
    By Paul-HB in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 11-29-2009, 04:59 PM
