Thread: FS: 930 oil pump, as new, race modified
    Smile FS: 930 oil pump, as new, race modified
    For sale is a fully prepped 930 oil pump, which was completely disassembled, inspected, modified for higher flow and reassembled by Aaron Burnham (Burn Bros) for Supertec. I am not certain if this was a new pump when the work was done, as I bought it complete.
    This turbo pump is as new...better than new actually and will outflow any factory 930 pump by a fair margin, although I don't know the exact lpm numbers.
    I yalked to Aaron today and this pump will make a GT3 oil pump cry.
    Configured like this one is, you'll spend $950 and have to wait, as they are built to order.
    You can have this one for $800 shipped in the USA.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Nov 2002
    Fremont, CA
    I think I remember that one
    I like to yalk to Aaron , too
    scott kinder
    kindersport@gmail.com
    Registry #614
    Aug 2007
    Phila Pa. area
    modifications
    What modifications were done to it?
    Mike
    I shot Aaron an email to get a description...my guess is that the internals were cleaned up to smooth the right angles that generate flow resistance and turbulence.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    modification description
    Regarding the machine work, I talked to Aaron today and the pressure side has been machined to get rid of the negative draft angles in the casting. The later pumps like the GT3, as well as the race pumps have this feature built in. Getting rid of the negative draft lets the oil flow down to the outlet/inlet instead of crawling up to it.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Taking offers...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. SCRS kugelfischer race pump.
    By stretch in forum Other Porsche Passions
    Last Post: 11-21-2017, 02:58 PM
  2. SCRS kugelfischer race pump.
    By stretch in forum Technical Info
    Last Post: 10-24-2013, 05:12 PM
  3. Modified or O.E.?
    By Fritz A. Ficke in forum General Info
    Last Post: 07-18-2011, 08:45 AM
  4. Race Gas vs Pump Gas..mix?
    By davewadd in forum Technical Info
    Last Post: 06-14-2011, 03:42 PM
  5. FS: 930 Turbo Large Oil Pump . Modified & Rebuilt
    Last Post: 10-29-2008, 02:53 PM
