Thread: Headlight Wiring Harness Help
    Aug 2006
    Chicago area
    The headlight wiring harness has the rubber through the body "grommet" (for lack of a better term) that mounts into each of the headlight buckets. The wires pass through this and it essentially holds them neatly in place and prevents moisture and debris from entering the bucket. Is this special grommet replaceable? My guess is not and when one is damaged beyond repair, you have to purchase a replacement harness with one built in.
    There are several other of these snap in grommets that are used around the chassis. What are your experiences in removing and replacing them? Hard to do? Technique? Thanks for the help.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    I go to my local friendly ACE hdw. store and pick from their grommet selection and find one as close as I can, then cut it with a sharp razor blade, slip it around the harness, and when pulled into the mounting hole the slit will virtually disappear. Use of something like Wurth clear silicone paste on the grommet greatly helps it to slip in.
    Aug 2006
    Chicago area
    Thanks Ed! I knew someone had an ingenious modern day solution.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
  1. Connector for headlight wiring harness
    By DJ911 in forum Technical Info
    Last Post: 08-13-2012, 05:38 AM
  2. Replies: 0
    Last Post: 11-04-2011, 02:00 PM
  3. WTB: Wiring harness for '69S
    By Dmill in forum For Sale: 911 Parts
    Last Post: 06-10-2011, 09:29 AM
  4. Wiring harness
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 09-03-2007, 06:28 AM
