Thread: Modifying E Cams
    Aug 2005
    VA
    Modifying E Cams
    Here's the delema.
    My cams are warn (not warn out) but have some miles on them. The shop doing my head rebuild suggested having them modified. What's the consenus here.
    Do I have them restored to stock E specs.
    Or
    Have them modified slightly (fatter ramps, slightly more lift)
    The car is a 73 911 E. I would love a few more HP but don't want to cause issues with the MFI
    Has anyone done this? Was there a noticable increase in top end HP? Was the MFI able to be dialed in to account for the changes in cam profile.
    What would you do?
    Chris
    73 911 E
    I've done it. The mod is a regrind the DC30 (mod-Solex) specs. John Dougherty does it and it is an ideal upgrade...way better than Solex and E cams. A full regrind is about $300 and your cams come out like new.
    See http://www.drcamshafts.com
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Aug 2005
    VA
    I have been talking to them about this exact grind as well as a slightly less agressive mofification.
    Any issues with fuel delivery from the MFI? Are you using an S (space cam) MFI?
    Chirs
    73 911 E
    I wouldn't call the DC30/Mod-Solex "aggressive"...it is pretty relaxed actually. I run stock springs and carbs on my '65 2 liter w/ Mod-Solex cams and the motor spins to 7K like lightning on small ports and valves, then falls off fast. Torque is very E-like, with more S-like rush on top. I think a little port floor work would liven the top end up a bit.
    MFI won't be an issue and an 'S' or 'E' space came would work fine on this cam. You might need to adjust the enrichment screws a bit for ideal AFR, but you won't have any issues.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Aug 2005
    VA
    I spoke to Gus at PFI and he said the E MFI should be fine with this setup.
    Chris
    73 911 E
  1. Modifying an inner Porsche pressed panel to create an early panel.
    By The MetalSurgeon in forum Technical Info
    Last Post: 10-22-2012, 08:35 PM
  2. FS 2.2S cams and MFI
    By BK911 in forum For Sale: 911 Parts
    Last Post: 07-22-2010, 08:21 PM
  3. Modifying Durant Mirrors
    By ErVikingo in forum General Info
    Last Post: 04-04-2005, 06:01 PM
  4. Modifying 911's
    By a911car in forum Technical Info
    Last Post: 02-27-2001, 09:17 AM
