Thread: Spark Plug question
    Spark Plug question
    I have a 1966 stock 911. Can you recommend plugs for city driving conditions? Are temperature ranges a consideration? Thank you!
    I can't remember the heat range I use. But I can tell you that I've tried a lot of different plugs and the one that works best is Bosch Copper..
    WR-5DC's work fine if you have retrofitted a CD ignition system. With the stock Kettering system, I'd use something warmer such as WR-6DC to keep them clean.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
  1. Spark Plug Wrench Question - 1968 911 Toolkit
    By bespoke in forum Technical Info
    Last Post: 07-11-2013, 08:48 AM
  2. Spark Plug Wrench Question - 1968 911 Toolkit
    By bespoke in forum For Sale: 911 Parts
    Last Post: 07-11-2013, 08:14 AM
  3. SPark Plug & Coil Question
    By ennisk1 in forum Technical Info
    Last Post: 10-30-2006, 03:06 AM
  4. Question about Spark Plug Gaps
    By gruen911 in forum Technical Info
    Last Post: 07-23-2005, 07:38 AM
