Results 1 to 8 of 8
Thread: Weber air screens for 40 &46IDA3Cs
    I have just made a batch of these hard to source air screens as used on race application Weber IDA 3C type carburetors. Originally supplied with 46mm IDA 3C carburetors for the 904/6, 906, 911R and various Weber carbureted race and rally cars these air screens filter debris that would normally enter the fuel bowl and plug the idle mixture jets. No longer available from Weber these air screens were duplicated from original air screens maintaining the same gauge and profile brass frame and screen material and are soldered as were the originals. Sold as a set of four screens with installation cheese head screws included.
    Contact me @ this email address if interested:
    Paul Abbott
    info@PerformanceOriented.com
    www.PerformanceOriented.com
    530.899.8371
    Paul Abbott
    Early S Member #18
    Weber service specialist
    530.520.5816
    Paul I am interested. What does a set cost?
    Richard
    I sell these for $150 per set of four with cheese head screws and split lock washers and if you live in California I must add tax. Shipping via USPS Small Flat Rate box.
    I'm in the process of making air horn screens as well so we may stop using tea strainers in the near future.
    Paul Abbott
    Paul Abbott
    Early S Member #18
    530.520.5816
    email sent.
    Richard
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Do these fit Spanish Webers too?
    RGruppe #183
    Id like to know the effect of removing the tall narrow vent tubes. 356-912 Solex 40PII early carbs had similar tubes that caused them to flood in sharp corners. They were superceded by low wide vent tubes which were better.
    Paul,
    I am new to this so ignore what might be an ignorant question but I recently bought a '72 so I am wondering if this is something that I would need for my 2.4 in a current unmodified state or is this something I would consider in an upgrade? The information is appreciated so i can make a decision.
    Dean
    These air screens fit all 40IDA3C type carbs, whether made in Italy, Spain or USA.
    They are for those not using air cleaners so they probably are not needed by you, Dean.
    The IDS carbs had short vent pipes (22mm long) with a 4.5mm ID where the IDAs had tall pipes (8mm OD x 50mm long) with 6mm ID. The 46mm Webers for race applications had no vent pipes and the hole in the top cover was 4mm in diameter. Sure would like some info here, I assume the racers didn't mind a little fuel coming out the top cover.
    Currently offered by eBay: Item number: 370446230254.
    Paul Abbott
    Paul Abbott
    Early S Member #18
    530.520.5816
  1. WTB: Weber air filter Screens
    By andrea70 in forum For Sale: 911 Parts
    Last Post: 08-18-2013, 08:43 AM
  2. Source for brass screens weber 46
    By preS in forum Technical Info
    Last Post: 08-15-2010, 12:59 PM
  3. Weber IDA screens - where to get ?
    By andyjboy in forum General Info
    Last Post: 06-30-2007, 05:31 AM
  4. Wanted: Weber Jet screens
    By Steve@Rennsport in forum For Sale: 911 Parts
    Last Post: 04-29-2006, 03:06 PM
  5. Looking for weber 46 brass screens for jets
    By RPMClassic in forum General Info
    Last Post: 11-23-2005, 03:23 AM
