Thread: excessive oil pressure
    Apr 2004
    35,000 ft
    so, I bought the hotrod in april, I guess I can say I hadn't driven it in really cool temps until this past weekend.
    oil pressure was always on the high side of normal, I'd see 100psi at startup...
    until this past weekend, very cool temps (40's) at a DE at watkins glen, I'd see almost 140 at startup, got me nervous.
    got to looking at the 3.0L oil sender, looks like it's setup for an SC gauge, part number 911-606-111-01, so I ordered a correct '72 sender calibrated for a 140 or 150psi gauge, hope that fixes the problem.
    anyone see flaws in my logic?
    Lewis
    Sep 2006
    La Quinta
    That should work...it fixed my problem.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Apr 2004
    35,000 ft
    ok, so which is the correct oil pressure sender?
    It seems there are 2 different thread sizes, smaller and larger....since I have oil fed tensioners, I need larger....but it needs to be calibrated to my gauge, which is 100psi, or I guess 7 bar.
    thanks
    Lewis
    May 2006
    CT
    Lewis
    I have a 3 liter in my '73 using the original '73 gage. I can help you with the right combination of hardware and sender to make yours work properly.
    Send me an email and I'll get you the details
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    The oil pressure relief valve can stick and cause high oil pressure.
  1. Very hi oil pressure!
    By Jay Laifman in forum Technical Info
    Last Post: 10-18-2013, 06:42 PM
  2. Excessive Tire Rub on 1970 911T Inside Left Front
    By hencar in forum Technical Info
    Last Post: 10-29-2012, 07:41 PM
  3. Oil Pressure
    By Jeff Trask in forum Technical Info
    Last Post: 08-29-2009, 04:54 AM
  4. Oil Pressure
    By KlaasyT in forum Technical Info
    Last Post: 05-04-2004, 06:28 PM
  5. oil pressure?
    By james in forum Technical Info
    Last Post: 01-26-2004, 06:41 AM
