Results 1 to 10 of 10
Thread: Bolt nomenclature?
    Bolt nomenclature?
    I have about ten socket head bolts and washers that attach the seat support to the car. I don't know what this are called, are they called M4, M5, or M6 hexbolts, does any one know the size and how one describes these bolts and washers. I was looking at Eagleday.com to purchase a set of yellow zinc plated bolts and washers.
    Thanks.
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    The bolts that attach the seat support to the car should be 6mm X 1.0 mm thread pitch allen head bolts. The allen head should use a 5mm wrench. HTH's
    Thanks for your reply. Did you mean 6mm x 10mm as I could not find 1mm?
    Also has anyone had experience in purchasing hardware from eagleday.com?
    Thank you.
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    Dec 2006
    Las Cruces, New Mexico
    I just took a quick look @ their site, they do not describe correctly in some places you have to dig. Ed gave you the correct bolt size/pitch since you have 10 measure one from the tip of bolt to bottom of the allen head that will be the length, they call them "socket heads" same thing as hex head.
    http://eagleday.com/m6sohebo.html
    Tried to edit out double Ed would not, system glitch.
    Early 911S member #166
    Apr 2003
    Portland, OR
    More than you ever wanted to know: http://www.jamesglen.com.au/training-manual/
    Harry
    Member #789
    2009 MB C300
    Atlanta, GA
    I find this web site to be helpful as you can drill down to specific types.
    McMaster-Carr
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    As Ed says 1.0 mm is the pitch.
    There are typically 3 different thread pitches available in Metric Fastenere.
    Ultra Fine, Fine and Coarse.
    The pitch varies with diameter and it convention that when a fastener supplier doesn't quote the pitch they will supply a coarse thread.
    If you order without specifying the pitch they will also deliver a coarse thread.
    As Ed also states the length of a cap head is specified as from under the head to the end of the thread.
    The only time this doesn't work is for Countersunk Cap Heads (CSK) when total length is used.
    Some of the cap heads used on door and window frames are also unusual as they have a 'low head' design. There are two DIN Standards for low head cap screws and the head depth is slightly different for both types.
    Stoddard
    900-119-091-02, Screw 6X15, $0.37 each
    May 2005
    Oroville, CA
    You beat me to it.. I always ask Porsche if they are still available. When I was in parts we carried every bolt size on the cars..and they were usually less than outside sources..sometimes even the same as original.
    H
  1. Four bolt flanges ? What is up with that ?
    By Gytis Kupinas in forum Technical Info
    Last Post: 08-28-2013, 11:01 AM
  2. Replies: 0
    Last Post: 04-02-2013, 07:02 PM
  3. Fan Shroud Clamp, 2 bolt vs. 1 bolt, 2.4 liter engines
    By caproader in forum Technical Info
    Last Post: 12-15-2010, 04:22 PM
  4. FS: Autopower Roll Cage - bolt in, bolt together
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 06-17-2010, 01:01 PM
  5. Gear set nomenclature
    By alfabender in forum Technical Info
    Last Post: 05-11-2009, 08:45 PM
