Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: SWB locking steering wheel option?
    Can anyone tell me if swb 911's had a locking steering wheel option? Specifically, 67.
    Thank you,
    Jim
    Jul 2003
    Vienna, St. Gallen, Stuttgart
    Hi Jim,
    my 2.0S SWB from 3/68 comes with a locking steering wheel.
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Is this option also on your kardex or COA or do you know the option code?
    Richard
    Jul 2003
    It does not show on my COA because it was a standard feature for 1968 on cars sold to Italy.
    By the way: does anybody know where to scource key blanks for this configuration (1968 with locking wheel)?
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Mar 2003
    Santa Monica
    Anatol,
    I would try Tony Euganeo, at LockandKeyID.com
    Best,
    Ed
    Early 911S Registry #224
    911S Targa 1973
    356B Roadster 1962
    Thank you Anatol. My 67 911 has locking steering, but as yours doesn't list it on the COA. I wonder if this was specifically for Euro cars? Unfortunately, I don't have the history from day one, so I don't know if my car was a Euro delivery.
    Thank you,
    Jim
    Jul 2003
    Quote Originally Posted by Edwin Ek View Post
    Anatol,
    Best,
    Ed
    Ed, thanks for your advice! I will give them a try.
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Hi,
    In case it helps we have both a RHD 67 and RHD 68 in the workshop and both do not have steering locks.
    Alan
    Alan,
    Yes, it's making me believe my 911 was a European model.
    Thank you,
    Jim
    In the 1965 Owners manual the only instruction for ignition is the 4 to the right key movement. This is the locking ignition. Ignition Part number ends in .00 .
    1967 Owners manual has instruction for the locking ignition (as above) and also the 1 to the left and 2 to the right key movement - Non locking ignition. Part number ends in .10 .
    The locking ignition has the 5 pin lock and the longer key, the non-locking ignition has the 4 pin shorter key.
    Either was available but some countries import reg's required non locking - if i remember correctly the USA was a non locking.
    Ask Tony Euganeo about the key length and the door lock type. There are two, "K" and another one.
    hth
    Bob
    Early S Reg #370
  1. Foamed rim steering wheel for 73S: standard or option?
    By vipergruen in forum Technical Info
    Last Post: 03-17-2014, 06:20 AM
  2. Wood steering wheel an option in 1970?
    By cjtbt in forum Technical Info
    Last Post: 08-02-2010, 07:35 AM
  3. 69' up Ignition assm with Locking Steering
    By eds73 in forum For Sale: 911 Parts
    Last Post: 04-22-2010, 08:36 AM
  4. FS 69' UP Locking Ignition/ Steering Switch
    Last Post: 04-19-2010, 02:45 AM
