Thread: Ignition Switch Question
    Well after 37 years I guess my ignition switch is going under. I have to turn it 4 or 5 times before I hit the starter spring.
    Can anyone rebuild these or do I buy a new one?
    Can they be rekeyed to my old key?
    Aug 2007
    Phila Pa. area
    iF YOU ARE TALKING ABOUT AN IGNITION SWITCH FOR A CAR WITH THE LOCKING STEERING WHEEL THE KEY PART OF THE SWITCH IS SEPARATE FROM THE ELECTRICAL PART, SO YOU DO NOT HAVE TO WORRY ABOUT THE KEY. There are 2 small screws that hold the switch part to the key and lock part of the whole assembly, then the wiring harness large plastic round thing plugs into the switch part. I have one if this is what you are looking for.
    Mike
    Mike
    I sprayed some liquid graphite into the lock to see if it gets better. Is your electric portion a new part? I'm going to crawl under there this weekend to see if it is possible to remove without taking the whole assembly out.
  1. NOS '69 911 ignition switch
    By Frank Beck in forum For Sale: 911 Parts
    Last Post: 08-27-2011, 12:22 PM
  2. Replies: 0
    Last Post: 08-13-2011, 01:19 PM
  3. Ignition switch help
    By 210bhp in forum Technical Info
    Last Post: 06-13-2011, 04:39 PM
  4. WTB: 67 ignition switch with key
    By Anthony67_911s in forum For Sale: 911 Parts
    Last Post: 10-12-2007, 02:20 PM
  5. ignition switch ?
    By robmog in forum Technical Info
    Last Post: 09-16-2007, 05:59 PM
