Results 1 to 2 of 2
Thread: Adding hand throttle control a 1966
    Any suggestions on adding a hand throttle control to a '66? I would like to keep my original ebrake assembly. Thank you.
    Why not use one from a 68 with the hand throttle and remove the heat lever, keep your heat lever the same? An elegant, reversible solution.
  1. MFI hand throttle adjustment
    By bliebler in forum Technical Info
    Last Post: 10-23-2011, 03:56 PM
  2. Hand Throttle help.
    By 1971-911T-Mark in forum Technical Info
    Last Post: 03-30-2010, 10:56 PM
  3. Hand Throttle Question
    By gnus911 in forum Technical Info
    Last Post: 07-20-2009, 12:59 PM
  4. Hand Throttle Decal?
    By fryardds in forum General Info
    Last Post: 02-25-2009, 04:44 PM
  5. Should my car have a hand throttle?
    By Davz912/911 in forum Technical Info
    Last Post: 03-19-2007, 02:00 PM
