Hi all,
Some of you may have seen my transmission rebuild thread on Pelican (1970 (911/01) transmission refurb issues). I'm in need of a few parts, for tools, and potentially for use in this transmission.
I'd be interested in a good 1/R slider (911-302-226-00-M260). These were the same part for all 901 and 911 transmissions (1965-1971).
I will be replacing the dog teeth (=synchro hubs) for gears 1-4. 1st gear is one part (10-1550-310-M184) and 2-4 are another (10-1550-315-M184). The higher gear hubs are mostly the same up through 1973, and used hubs from gears 4-5 may be very useable.
I could also use 4 synchro bands (911-302-301-06-M260). These were identical for all gears from 1965-1973. Again, used bands for the higher gears could still be useable.
Finally, I'd like an old junk 1971 or earlier clutch disk to make an input shaft holding tool. I'll just be cutting out the center, so essentially any condition is fine.
Please provide pictures and prices. I'm looking to save some money over new parts, but don't want junk. If you've got some old dismantled gearboxes around, I'd be grateful to see what you have.
Mike
