Thread: help needed with horn issue
    I'm trying to troubleshoot some final bits on small intermittent electrical bugs that haven't been completely resolved, the first being the horn: new horn contact, fuse is good, connections to both horns are good yet when I depress the horn I hear a slight clicking sound but no horn- any ideas? The clicking would indicate that contact is being made I assume- it was working a few months back but then just stopped. Any help would be appreciated.
    Thanks, Marco
    1971 911S Silver Metallic
    1970 911E Conda Green
    1974 MFI Carrera
    S Reg #1245
    Senior Member rgrimm's Avatar
    Jan 2006
    Fargo, ND
    Are you sure the horns are still good? I replaced my 68's horns maybe 10 years ago. When they both stopped working, I assumed it was a bad electrical problem--really, who would expect new horns to both fail in that span of time. When I noticed I was getting clicking from the relays, I took a chance and bought an inexpensive pair of horns on eBay and that did it...
    Roger
    68 Sand Beige 911 Coupe #11830091
    84 Moss Green 911 Carrera
    Hi Roger- I actually just walked in from having solved the issue- it was a bad relay! I initially thought what you suggested but it would have been odd if both horns had gone bad at the same time, that's why I then thought it was a connection issue.
    1974 MFI Carrera
    S Reg #1245
    Probably your horns, both of them. Take a wire from the + of the battery (ground the other horn contact local) to the other horn pin. If horn clicks, bad horn..
    -Allen-
  1. horn contact pin question/issue
    By Kaleid in forum Technical Info
    Last Post: 10-14-2013, 06:34 AM
  2. Pricing Help Needed: Leather horn pad
    By Tony Scheurer in forum General Info
    Last Post: 12-07-2012, 03:31 PM
  3. Pricing Help Needed: Leather horn pad
    By Tony Scheurer in forum For Sale: 911 Parts
    Last Post: 12-07-2012, 05:38 AM
  4. 72T fuel distributor issue, information needed
    By Greg D. in forum Technical Info
    Last Post: 08-05-2012, 11:09 AM
  5. Christophorus Issue needed
    By Rick Cabell in forum General Info
    Last Post: 03-29-2009, 12:32 PM
