Thread: Mainshaft (GA) from 65 box - OK with 2.0s?
    Member #1525 gilbert911's Avatar
    Oct 2006
    Europe
    As the title says.
    Have a GA mainshaft sourced from an early 65 911 box.
    Should it be robust enough to be mated with a 901/02 2.0s stock engine?
    Tyres are skinny at 5.5"
    No LSD
    I have read that the imput shaft is not as strong (1st gear) as the later boxes. Would I be correct in this and should I be concerned?
    Suppose the alt would be seperate mainshaft and GA gear, but expensive.
    Thanks for advice
    Sep 2006
    La Quinta
    I have one and have never had a problem.
    1965 911 #301111, Red Book Vol 1 "Cover Car," owned 53 years.
    1967 911 #307347, bare-bones, some road wear, a little surface rust, and a few dents..., owned 13 years.
    Registry #983
    R Gruppe #741
    GA second is not a 2,0 liter gear, it's a 2,2. AGAOVZA 70-71 only.
    It's fine with a 2,0 S
    The problem is that first isn't as strong because it's cantilevered off the end of the mainshaft inside the end cover. If you have a 3,0 motor and hammer first it will pull the gear off the end of the shaft.
    No concern about doing that with a 2,0 S
    Oct 2006
    Europe
    Getting alot of help from you John!
    Thanks again
    Chris N
    Oct 2008
    Burford, ON, Canada
    The GA mainshaft came in the first 911 transmissions in 1965 models (type 901/0), and also appeared in several other types later on such as the 914/01. It had a 12mm nut securing first gear in the 1965 version. Later mainshafts had a 14mm nut instead. As long as the transmission is lightly loaded it should be fine. If you have questions, then I suggest contacting Grady Clay for definitive information on these early mainshafts.
    I think you would like the performance of your car with the lower F shaft a 2.0 came with
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
  1. FS: 901 GA mainshaft
    By Brant in forum For Sale: 911 Parts
    Last Post: 05-28-2013, 01:05 PM
  2. FS: NOS 904 Mainshaft
    By Mr9146 in forum For Sale: 911 Parts
    Last Post: 08-10-2012, 11:33 AM
  3. GA Mainshaft
    By jhora in forum For Sale: 911 Parts
    Last Post: 02-26-2008, 07:49 PM
  4. NOS 904 mainshaft FS
    By lisa_spyder in forum For Sale: 911 Parts
    Last Post: 04-03-2007, 12:50 PM
  5. WTB 904 mainshaft
    By ixxifan in forum For Sale: 911 Parts
    Last Post: 11-09-2006, 08:43 AM
