Thread: Soft window removal?
    Has anyone removed the soft window portion of the Targa to replace it? I see fasteners at the rear, bottom section from inside the car, which looks straightforward to get that end off. But it's the top section I'm having trouble with. I've pulled down the two release handles under the Targa bar itself, but nothing releases. Is there a trick to getting it out?
    Thanks in advance
    John Schiavone
    Connecticut
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    Your handles should have a stop screwed onto the base to prevent the part on the upper hoop from losing its indexing on the threaded portion of the lever. If these are present, you can unscrew them which should allow you to move the lever far enough to disengage the two parts. As I recall, there isn't a whole lot of travel in the upper bar. If you are wanting to get more travel, you'll need to pull off the bolts at the base of the Targa bar.
    Here is a link that shows most of the soft window parts and pieces.
    Soft Window Targa Details
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    Jul 2008
    near Ottawa, ON,canada
    pm your e-mail and i will send you the instalation instruction , and just work them in reverse
    yves
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    Senior Member curtisaa's Avatar
    Pasadena, CA
    Swt
    Good luck with the "doing-it-in-reverse". It's not that easy all the time. I've restored several SWT's and in order to replace the entire rear boot you will have to completely remove the entire boot. If, you only want to replace the rear window, for visability purposes, that can be done by a savy Porsche knowledgeable upholstery guy.
    Good luck and gratis to you for saving another SWT...
    [FONT="Lucida Sans Unicode"]
    Curt Autenrieth
    S Registry # 152
    Porsches:
    1.6L 2.7L
    1.8L 3.0L
    2.0L 3.2L
    2.2L 3.4L h20 cooled
    2.4L 3.6L air & h20 cooled
    3.8L
  1. Replies: 9
    Last Post: 08-24-2022, 03:21 AM
  2. Advice on Soft Window Targa vs Fixed window
    By Max (SD) in forum General Info
    Last Post: 08-04-2013, 03:22 PM
  3. Soft Window Targa to Fixed Window
    Last Post: 03-04-2013, 02:11 PM
  4. help! removal of rear window Targa
    By EARLY911ZOO in forum Technical Info
    Last Post: 07-10-2008, 06:20 AM
  5. Targa Rear Window Removal
    By eaglenav1 in forum Technical Info
    Last Post: 05-30-2001, 12:24 PM
