Thread: Heater box hose?
    Aug 2005
    VA
    Heater box hose?
    Are the large (approximatly 4 inch diameter) paper covered tubes (hoses) on the back right of the engine available anywhere? The next best thing I am told is aircraft SCAT tube but it would be perrferable if I could replace with the stock component.
    Chris
    73 911 E
    Well, they are not four inches, they are 60mm, available new from Stoddards or Pelican. Black coated aluminum. I assume you mean the ones between the air ducts on the fan shroud and the heat exchangers.
    Aug 2005
    VA
    This one right 901-211-194-00? Connects the Right Side Heater Duct to the heat exchanger.
    Chris
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
  1. WTB: Right side heater hose
    By NickP in forum For Sale: 911 Parts
    Last Post: 06-23-2012, 06:58 AM
  2. Heater hose colour
    By PhilJohnson in forum Technical Info
    Last Post: 07-10-2002, 08:15 AM
  3. Heater hose size?
    By 911SRegistry in forum Technical Info
    Last Post: 02-18-2002, 11:51 AM
