Results 1 to 8 of 8
Thread: 1965 Sill/Jacking Point Detail Photo Needed
    Hi All,
    Can someone show me a detail photo of the left and right jacking point of their 65MY car please? Must be original, factory fresh (or rusty), un-tampered with please!
    Many thanks
    David,
    This is a '66 MY, not 65. . . but this is the most rust free example ever posted, you can even see the old factory MIG wire where they cut it off!
    That is a great shot. Can you show me a pic looking into the jack receiver square hole thingy. I'm led to believe there is a wind deflector?
    There is nothing apparent in the jack tube but the open end to the kidney bowl is quite common
    Quote Originally Posted by LGK6D View Post
    Do you mean this?
    Chris, that is a VW hub cap puller.
    (ignore my reply if you were pulling David his leg).
    Richard
    Oct 2008
    Burford, ON, Canada
    Richard, here is an example of a VW hub cap puller, one of only two styles I know of; the other is similar but a bigger loop for fatter fingers. The one above looks more like a spring, so I suggest it does go with the cap it is in.
    Ha ha, no not jacking point covers or hub cap pullers
    I'd like to see the exact same photo but from a horizontal prospective. I'd like to see how the sill and jacking point intersect from the side.
    Thanks so far though.
  1. 70S oil cooler shroud detail pix needed
    By TRE Cup in forum General Info
    Last Post: 12-27-2014, 09:52 AM
  2. Satanic detail, help needed! Repa seatbelts.
    By Mike_Moore in forum General Info
    Last Post: 03-22-2010, 06:54 PM
  3. Sill detail on 65 911
    By Alan B in forum Technical Info
    Last Post: 05-24-2008, 02:41 PM
  4. What Speed is Needed to Beat the Photo Radar
    By gruen911 in forum Off Topic
    Last Post: 11-10-2005, 03:20 PM
  5. Photo of Sport Kit catch can location needed
    By Rennman in forum Technical Info
    Last Post: 08-08-2003, 03:40 AM
