Thread: Rear window heating?? 911S 1968
    Senior Member egbert's Avatar
    Mar 2007
    Amsterdam
    Question Rear window heating?? 911S 1968
    Hi everybody
    Can anyone help me out with the following:
    I have a rear window heating switch on the dash but only grey rear window tubes ( as in the pics) so no electric rear window heating?
    And ,Is this the proper way to install the grey tubes??
    rgds egbert from holland
    Since you mention rear window heating/defog for early cars , I have been wondering about this unit. I see it on a good amount of 911's in 1968 & 69 at rallye (usually Factory entry cars) .
    Here is one on Pauli Toivonen's car at the 1968 Monte Carlo , which was a factory entry:
    Anyone know what manufacturer made this unit ? Was it a factory accessory ? I'm assuming it was attached to the inside of the glass versas embedded. Anyone know any details ?
    No. 116 , Pauli Toivonen - Martti Tikkanen (2nd overall)
    Pretty sure that exposed clip on the back goes under the rubber window gasket and hooks over the edge of the window opening
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    As per Brett Johnson`s PORSCHE 911/912 book,1967 -1968 911 (page 28) had an optional heated rear window with vertical heating elements.I have one and there are about 80 plus very fine/thin elements with a single stage dash mounted switch.....Cliff
    Nov 2003
    Sydney
    The demister on the rally car was an aftermarket item.
    They were a very common addition on English cars of the era - cant remember the brand name though.
    HTH
    Dennis.
    S Registry member 536
    Izenglas
    Used in cold climate to put a airspace between too clear surfaces and eliminate fogging of the window. The black line is a 1/8" thick rubber with adheasive. Real big item prior to adequate defrosting fans/heaters. This was much better than the Barclays card (twice as thick as a standard US credit card) used to scrape the INSIDE windows of VW 's and Porsches in the 1960's -70's.
    Bob
    Early S Reg #370
  1. Replies: 27
    Last Post: 03-09-2017, 06:54 AM
  2. 1968 911S Soft Window Targa 1 of a kind 150k
    By Paul-HB in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-23-2016, 06:02 PM
  3. Seeking rear Targa Glass with NO heating elements.
    By CidTito in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 04-03-2012, 07:16 PM
  4. WTB: 911s soft rear window targa
    By rower in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-29-2011, 11:47 AM
  5. 1968 911 L Sofr rear window targa
    By King Clemons in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-18-2007, 02:57 PM
