Results 1 to 10 of 15
Thread: WTB "RS" steering hub extension
    Feb 2010
    San Francisco, CA
    Anyone have one they don't want or need?
    I'd also appreciate a commercial source if anyone has one.
    Thanks!
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Dear Kent,
    Maybe here you find your hub extension: http://www.rsr911.de/
    I have no affiliation.
    The seller is posting on Ebay.de pretty often.
    48 h left: http://cgi.ebay.de/Porsche-911-S-RS-...item35ae25b8c9
    Br
    Joachim
    Feb 2010
    San Francisco, CA
    Thanks Joachim!
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Another source which I actually used. From my point of view very nice in terms of quality and plug+play. But pretty expensive: abt. 450 $ plus shipping.
    Feb 2010
    San Francisco, CA
    Interesting solution. So how does the extended hub attach? Do you cut the rivets off the stock hub and mount to the extended?
    Please let me know where this one came from and I can add it to the list.
    Cheers
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    The extended hub above is much bigger than the factory solution. Very expensive too!
    I made a couple of runs of retrofit extenders a few years ago which were well received. Here is the thread. http://www.early911sregistry.org/for...t=hub+extended
    It is a bit of work drilling out the rivets, but the result is excellent. I would consider another run at a $150.00 each including the horn button support insert, but I would need a commitment of at least six units.
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Hello Kent,
    you are right, the rivets are drilled of and wheel + stock hub are mounted with screws. As mentioned by Cornpanzer the dimensions are bit bigger and the shape is
    conical. A friend of mine www stimming de has had them manufactured for use on his RS and due to expensive manufacturing process he did 10 in access.
    While not a 100% copy of the original it appears to be lighter and the look is in my opinion very harmonious.
    BR
    Joachim
    Feb 2010
    San Francisco, CA
    I'd certainly be interested in an extension if priced in the $150 range. Let me know if others want to join in and make the minumum limit.
    -Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Dec 2006
    Bedford NY
    I'm in for the next run of extensions...
    Eric W.
    72 911T euro 3.2 T-Rally tribute
    73 CS30 original survivor
    56 Healey 100M
    70 Giulia 1300Ti 2liter
    Tour Auto 04/05
    Colorado Grand 03/04/05/07/08/11/17/18
    RG # 650
  1. FS: Special Extended Hub 380mm "RS" "RSR" Thick Grip Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 06-06-2014, 12:47 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-17-2012, 07:56 AM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-09-2012, 07:53 PM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
