Thread: FS rebuilt alum 911 2.0 engine
    1968 911 2.0 cast aluminum engine, 901/17 completly rebuilt including the following;
    New
    Biral pistons and cylinders, rings, pins
    Intake and exhaust valves
    Intake and exhaust valve springs
    main, rod bearings. std.,std.
    930 chain tensioners and safetys, chains , chain rails
    Connecting rod nuts and bolts
    all gaskets and associated hardware
    Re-conditioned rocker arms
    Perfect 911 T camshafts
    This is a 130 hp engine originally fitted to a Sportomatic car.
    $6000.
    The price reflects the cost of the rebuild, no core necessary
    Aluminum engines are the strongest but are becoming more difficult to find.
    Sold as you see it , will help with shipping ( delivery to local dock) Already in
    wooden crate on pallet From zip 07652
    Rory 201 291 7994 or rgalla9146@aol.com
    Just wondering, is there a reason you choose to use the intermediate shaft cover for a magnesium case? Do you know if it has the intermediate shaft w/o or w/ bearings?
    Richard
    What are the differences [if any] between the 911 T cams you used and the stock cams? Thanks in advance---JON
    ORE67S
    67 911S-SILVER
    65 356SC COUPE -SOLD
    73 914 2.0 YELLOW [74K]
    74 914 1.8 WHITE
    Hello Richard
    Aluminum cases didn't have intermediate shaft bearings originally as you probably know.
    Although I build engines myself I didn't do this one. The mag cover probably indicates an update. This can be verified by removing the cover.
    Intermediate shaft bearings are listed among the new parts but I neglected to list them in the ad.
    Thank you
    Rory
    Hello Jon
    The stock cam would be the same as used in type 901/06 The T cam is as used in 901/ 03
    Diffrent valve timing, broader torque curve. This cam / compression ratio results in an engine output between these two versions.
    Quote Originally Posted by rory gallagher View Post
    Hello Richard
    Thank you
    Rory
    This case than has been modified for a later shaft and therefore uses a mag cover plate? I have no experience w/ this kind of modification(s) and try to learn from others who have.
    thanks
    RIchard
  1. FS: 1968 Engine - Parting out - Mag Case, Alum Chain Boxes, etc.
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 05-04-2023, 07:23 AM
  2. Engine number 3281590 mag or alum?
    By srogebry in forum Technical Info
    Last Post: 05-23-2012, 07:06 AM
  3. Where to buy? Alum rear decklid, alum S bumper
    By mjshira in forum For Sale: 911 Parts
    Last Post: 03-25-2011, 10:53 AM
  4. Value of alum engine lid, used?
    By Paul Schooley in forum General Info
    Last Post: 10-20-2007, 04:05 AM
  5. FS: 1967 911 Alum. Engine Complete
    By mrbmw2002 in forum For Sale: 911 Parts
    Last Post: 10-08-2007, 07:20 PM
