Results 1 to 8 of 8
Thread: What's this wire (behind oil multi-guage)
    Feb 2010
    San Francisco, CA
    Can anyone help me with identifying the green wire sitting unattached behind my oil pressure/temp gauge? It's solid green and the spade connector is wrapped in electrical tape (circled). Makes me think it should be or used to be attached to something.
    OR, it's not important and I should just leave it alone
    Thanks for the help!
    -Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Sporto overtemp wire, taped off by the factory.
    Feb 2010
    San Francisco, CA
    Excellent! Thanks. Didn't look like a factory job to me.
    -Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Funny, I have the same spare green wire in the same location, actually near fuel/tank level gauge, on my late 66 911 (pre-SportO). Other solid green wire is connected to fuel gauge from tank. All other instruments work.
    John Schiavone
    Connecticut
    I also have this wire in my '68, which was originally a sporto! I've lived to see the "other end" in the engine bay, too! It's the only remnant of it's sporto past that is left.
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    I just wanted to say thanks for this thread - as I'm putting the gauges in my 912 -> 911 conversion, I'm swapping over the gauges wire by wire and was really mystified by the solid green wire attached to the overheat light on the oil temp gauge as it doesn't appear on the wiring diagram I have. Referenced to a sporto diagram and now I can stop fretting about what this mystery wire is for!
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Atlanta, GA
    Thanks for all, I have this wire too and had not been able to get an answer. Now I feel better knowing that a PO had not cut it.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    That's right! And now how about the other end? Mine was loose in the back (front of car) of the engine comparment to be possibly plugged in by mistake to the oil pressure sender! Thanks.
    -Allen-
  1. Replies: 1
    Last Post: 06-17-2013, 10:37 AM
  2. The multi million dollar T has a web site now
    By 78mochasc in forum General Info
    Last Post: 03-28-2013, 09:51 AM
  3. Multi use daily driver help needed!
    By Soterik in forum Off Topic
    Last Post: 02-09-2012, 08:55 PM
  4. Multi-colored Early 911
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-02-2008, 12:09 PM
  5. 1969 turn signal multi-switch
    By ljowdy in forum For Sale: 911 Parts
    Last Post: 08-17-2007, 11:05 AM
