Thread: 911R lenses and lamp bases
    Aug 2003
    Van Nuys, Ca
    Doing a little housekeeping and we found ourselves with extra lenses, lamps , and bases. These are made by Hella, as the originals were on the R.
    The amber and clear lenses are $25 each, the single bulb plastic bases are $5 each, and the complete red lens/single bulb units are $35 each
    Limited quantities at these prices. Shipping available worldwide. Fiberglass mounting bases available separately too
    Of course we can supply you with the complete new units as well
    Contact Dave at tremotorsports@gmail.com
    pay pal accepted, but add 3%
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Email sent
    John Schiavone
    Connecticut
    Aug 2003
    Van Nuys, Ca
    E mail responded to
    I wish to make it clear on what the single bulb bases mean. There is only tabs to mount one bulb. So an amber /red or amber/clear lens will be entirely illuminated by that one bulb.
    There is a solution, though not the most elegant, it is effective in converting these bases to dual bulb. The metal inserts can be removed, a divider plate made from a bit of scrap aluminum or tin, then holes drilled in the bases so a usually available 194 base bulb socket can be glued into place. The advantage of the 194 series is a wide variety of colors, wattage, LED versions and certainly less $ than the german "tube" bulbs.
    So as of today (12/18/10) I have 8 more red lamps new in box, TWO more amber/clear lenses (new), and about 20 single bulb bases.
    After that its back to the new retail pricing (contact me)
    thank you
    Dave
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
  1. Fog Lamp Lenses for 71 S
    By beatnick65 in forum Technical Info
    Last Post: 04-23-2013, 12:54 PM
  2. Hella 911R lamp & lens oddments
    By andyjboy in forum For Sale: 911 Parts
    Last Post: 04-09-2012, 10:10 AM
  3. 911R Lamp Housings
    Last Post: 03-09-2012, 03:10 AM
  4. fs: 911r taillight lenses
    By garyz in forum For Sale: 911 Parts
    Last Post: 06-17-2009, 10:57 PM
  5. 911R Front Lamp kit w/brake duct
    By Mark Morrissey in forum For Sale: 911 Parts
    Last Post: 09-07-2008, 07:33 PM
