Thread: WTB: solid chain tensioners; collars?
    Junior Member
    Jul 2007
    Enumclaw, WA
    For a 1965 2.0 engine. Is $50 shipped about right? I will go higher if necessary. I want to stay stock, I'm also considering the tensioner collars. The engine is inching closer to being revived.
    Quote Originally Posted by project66 View Post
    I have both. Take your pick.
    Collars for $25 shipped or tensioners for $50 shipped ... to the lower 48.
    -Marco
    TLG Auto: Website
    Junior Member
    Jul 2007
    Enumclaw, WA
    sent pm, thanks
    I appreciate the help.
    Victor
    Restoration newbie.
    Jun 2007
    San Francisco
    Solid tensioners are only for racing where you will be inspecting the
    timing chains and manually adjusting the tensioners regularly.
    For stock appearance you want rebuilt 930 tensioners. There are many
    different styles as they evolved over the years. The best type are
    narrower at the top bolt to accomodate the wider idler arm.
    The earlier wide casting with the 930 part number is also ok if you can
    machine the top 10mm to accomodate the wider idler arm. These
    wider arms are less prone to binding on the bolt which is part of the timing
    chain failure story.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    I like solid tensioners for the street. Nothing is as reliable and adjusting is easy [every 10-15,000 miles]. I think the idler binding problem started when they took the bushings out of the idler arms [in 1969?]. The early bushed arms seem to hold up well with no galled pins on early aluminum motors but wide idler arms would be better.
  1. FS: NOS chain tensioners
    Last Post: 03-16-2014, 02:53 PM
  2. Need help, chain tensioners
    By Norm01 in forum Technical Info
    Last Post: 02-07-2014, 07:58 AM
  3. solid chain tensioners or Pressure fed??
    By mwalker09 in forum Technical Info
    Last Post: 01-06-2013, 05:58 AM
  4. Chain Tensioner Slip Prevention Collars
    By MoparBoy72 in forum For Sale: 911 Parts
    Last Post: 12-06-2010, 04:55 PM
  5. F/S OE Chain Tensioners & Spacers
    By Bobby Smith in forum For Sale: 911 Parts
    Last Post: 02-27-2009, 12:58 PM
