Thread: Needed: Sportomatic manifold valve
    Jul 2008
    South Florida
    WTB: Sportomatic manifold valve
    Restoring our '68T Sporto and found a small problem: the small bronze spring in the manifold vacuum valve is broken in two.
    Looking for either a complete working valve for the 905 gearbox, or a source for the spring and diaphram material. The correct sized replacement spring we found is too stiff. I'm afraid it will prevent the proper amount of vacuum from the manifold. If anyone knows the spec for the correct stiffness of the spring that would be a huge help... ditto membrane material.
    Many thanks in advance... the Sportomatic.org site is Tango Alpha.
    Felix Natividad, ya'll.
    EDIT Thank you Maurice @ Stoddard. Part is available from Porsche if somewhat dear: $125 each. Will disassemble one to determine the spring tension and make some spares!
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Member 1488 MrJTP2001's Avatar
    Nov 2008
    Denver area
    If we're talking about the check valve that mounts to the left side manifold, I found the same problem; broken spring. I did a lot of searching and found some to be available at popular dismantlers.
    Tony
    68 Sporto Project
    2016 Boxster
    May 2006
    CT
    Russ
    If you are talking about #21 in the attached diagram...I've got one available.
    PM me if interested.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Jul 2008
    South Florida
    Thanks for putting up the parts illustration, Tom. Not the servo (#21) but the manifold valve (#12).
    Russ
    ESR # 1537
    '70 914/6 GT
    Nov 2008
    Denver area
    Russ, I sent you a private message.
    Tony
    68 Sporto Project
    2016 Boxster
  1. FS: Sportomatic Air Control Valve
    By jwoods in forum For Sale: 911 Parts
    Last Post: 02-17-2016, 05:51 PM
  2. WTB: Urgently needed LHS heater control valve in trunk
    By murph2309 in forum For Sale: 911 Parts
    Last Post: 03-22-2014, 08:00 AM
  3. Replies: 0
    Last Post: 07-28-2013, 09:03 PM
  4. WT Swap PMO Manifold
    By Fishcop in forum For Sale: 911 Parts
    Last Post: 09-16-2012, 02:39 PM
