Results 1 to 10 of 14
Thread: How to determine the year of an early car when you see one on the street?
    Mar 2005
    The other day I was in the parking lot of Whole Foods and I noticed an early car drive by and tried to figure what year it was. From a hundred feet or so I only had time to note that had rubber on the over-riders so it couldn't be a '65 or '66. Does anybody have a way of determing the year of a car from its external appearance?
    Don
    _______________________
    1965 912
    1981 911SC
    2006 Cayman S
    66 can have rubber on the over riders (bumper guards?) too
    if it has a angled script (911 or 912) it's pre August 66
    if it has a T in the rear lid and a 3? bar grill it's pre (approx) calender year 68
    Richard
    Don,
    If we're talk'n stock 911's.... I do it this way
    A short wheel base 911 has the rear edge of its torsion bar cover very close (almost touching) the front of the rear wheel well opening. A long wheel base 911 has about 2 fingers width between the rear edge of the cover and the front of the wheel opening.
    I this country it's rare to find a 'short car' earlier then a '66 ... so you've probably got 3 choices between '66-'68. A '66 has the 911 script on a slant on the rear deck and a wood trimmed dash. A '67 has its 911 script straight under the rear grill, and an aluminum trimmed dash. A '68, if stock, has side marker lights. If you see a 'long car' with 'button' door pulls it's a '69. A long car with 'trigger' door pulls and no oil filler door and no 2.4 grill badge is a '70 or '71 (very hard to tell the difference from the outside). If it's a long car with a oil door it's a '72. And if it's a long car with a 2.4 grill badge, no oil door, black plastic horn grills, and black surrounds on the direction lenses, it's a '73.
    Hope this helps...
    Let's see where I screwed up......
    Senior Member Milou's Avatar
    Mar 2006
    Geneva
    This Thread could provide you with some info:
    http://www.early911sregistry.org/for...roduction-year
    Milou / Registry #884
    www.ecurielyford.com
    Jul 2006
    Switzerland
    Chuck, I do it exactly this way too - Torsion bar cover > SWB > LWB and so on...
    Btw a 70 and 71, the key lock type (vertical or horizontal) gives a clue.
    Or, assuming the owner put it right, the position or typ of the Weltmeister decal.
    Registry member No.773
    Mar 2005
    Chuck,
    Great. Thanks. But it would be hard to make out all those details as a car is driving by!
    So reducing this down to the fewest details and using elimination I would first look at the torsion bar covers. If it is a short wheel base: and has side reflectors (68), has angled 911 script (65/66), none of these (67). If it is a long car with no 2.4 badge it is a 70 or 71 unless it has a button door handle. If it has a 2.4 badge and an external oil filler door it is a 72, otherwise (73). Thanks again. Now I just need to memorize these.
    Don
    ________________________
    1965 912
    1981 911SC
    2006 Cayman S
    I do it the same way!
    Horn grilles, big or little?
    If viewing from the side, the door handle and the torsion bar cover are immediate tells for an SWB.
    If SWB with "flying buttress" door handles then it's a 68. If LWB, then it's a 69. As Chuck says, any side reflector is an instant 68.
    If SWB and not a 68, then look at the lid. 65 and 66 have angled script, 67 has script up by the grill.
    65 vs. 66: look inside for a four button dash or the short knee pad, or the mushroom vs. eight-ball knob.
    If LWB, 70, 71 hard to tell apart. 72 has oil door. 73 has rubber baby buggy bumpers and blacked out trim.
    74-77 have the same narrow flares as the LWB longhoods with a short hood and bumpers.
    SC has "carrera" flares and the foglamps are mounted off the front valance.
    84- Carrera has foglamps mounted IN the front valance
    87-88 G50 Carreras have a big torsion bar cover under the rocker panel.
    89-92 964 have flat mirrors
    93-94 964 have aero mirrors
    Who can do the 356 from pre A to T6?
    When it's a LWB, I like to take a look at the A-pillar, too. It's like getting a grade on a test.
    -Marco
    TLG Auto: Website
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by dhopkins View Post
    I usually flip a U, chase the bastage down, jump outta my ride and accost the fella. Usually pretty effective..... You can't be to careful with all those hot rods out there. No tellin what ya got.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Don, it's pretty easy....just follow these step by step instructions.
    1. follow the guy to the first available traffic light
    2. toot the horn
    3. roll down the window
    4. ask what year it is....and say 'car looks great'
    .....this tends to be the easiest.
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    SOLD - 1967 911N / 1968 911L / 1967 911N / 1969 912 / 1991 964 C2 / 2013 991.1 / 2008 987 Cayman
  1. Determine what ratio gears one has in a 915 Transmission
    By Bavaria911 in forum Technical Info
    Last Post: 11-25-2013, 07:35 PM
  2. 306943S.......Please help determine what I have
    By Fred Zerk in forum General Info
    Last Post: 10-21-2013, 07:53 AM
  3. FS: Early-Mid 60's Porsche Street Sign Coasters
    By Carl Bauer in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-26-2013, 09:44 AM
  4. used koni shocks--how to determine if they are good?
    By gary basil in forum Technical Info
    Last Post: 04-25-2013, 05:56 PM
  5. Trying To Determine Correct Engine Number
    By 69S-S/R in forum General Info
    Last Post: 08-07-2009, 05:14 AM
