I have a 65` long block that has a duel pulley; any ideas why a 65` would need such an arraignment?.....Cliff
Yes , the crank pulley..sure seems strange on a 2.0...I have a 72 T with ac and that`s pushing it with the stock equipment from that era.....
aren't those lines for centre lube cams rather than oil fed tensioners?
andy
67S in pieces
EarlyS: 1358
[SIGPIC][/SIGPIC]
Cliff, check out the cam boxes. . . you should find that there are NO bosses cast into them for the spraybar fitting on one end (and plug on the other). All this is 65 stuff, pretty rare and should be preserved, preferably with the original case.
Here is a pic of Dick Strahota's car at the '05 parade, illustrates the plumbing for centerlubes pretty well.
Those are defintely the oil lines for the center-lube cams! Mine have caused me quite a bit of grief: even though they should be easy enough to build they're extremely rare.
I had my '65 at an all-marques concours and the judges got into an argument among themselves over whether or not I should be marked down for adding pressureized chain tensioners. PCA rules by the way say that for concours purposes that upgrade (which is very difficult on the really old engines) should be considered "original."
I think I may have seen a dual pulley engine before...could it have been a racing engine to discourage slippage?
Jim Alton
Torrance, CA
Early 911S Registry # 237
1965 Porsche 911 coupe
1958 Porsche 356A cabriolet
I`ve always considered it to be for the center lube cams, although I have never pulled the covers to check it out. Too, the left cover has a metal block off for the Solex fuel pumps.Engine # 900685
Must have been changed to Webers at some point.
1962 356 Cab, show car, sold.
Registry #983
R Gruppe #741
